Hi, I posted a while back about an intermittent fault with my ABS (car is a W(2000) Bora 2.8 V6 4mo, so full ESP etc)
I have now had the fault codes read, and would be interested in what you guys think could be the cause!
The printout says the following:
Code:
1 fault recognised
01279  027
Longitudinal acceleration sender-G251
Implausible signal
sporadic fault
I understand this points to a sensor in the steering column, what sort of cost/time am I looking at to replace this?
Thanks in advance!
