Thread: ipod confusion audi models
Page 4 of 36 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 356
  1. Re: ipod confusion audi models
    #31
    Milton Keynes
    I'm struggling to get my iPod linked up.
    Can you tell me if the following combination is possible and if so where I can get a suitable lead.
    I have a 54 plate A3 with Concert radio, part number8p 00 351 86C and I have a VAG iPod adaptor kit from my MKiv golf that had a Gamma radio. The number on the "black box" part of the kit is 000 051 444K. I have both leads that came with the kit and neither fit the A3, I asked at the local dealer and they supplied a lead but when I got it home I realised it was the same as one of the leads I already had! (A8E0 051 445A)
    I'd be really grateful if you could advise a) is it possible and b) the number of the lead I need before I try and sell the kit I have and have to buy another from Audi.
    In advance......Many Thanks
    John.
    Newbie (ish!)....A6 Black Edition
  2. Re: ipod confusion audi models
    #32
    May 2007
    knee deep in clunge
    14 Post(s)
    post a picture of the lead
  3. Re: ipod confusion audi models
    #33
    Milton Keynes
    Thanks for the reply!
    OK, here's the leads I have but don't seem to fit, I assume I should be looking for the multi play cd socket as it was on the golf, if it's going to work at all!
    I have included a pic of the "black box" if this helps.
    Thanks again for your time!
  4. Re: ipod confusion audi models
    #34
    May 2007
    knee deep in clunge
    14 Post(s)
    the blue connection is for double din units
    the other is for single din (yellow green and blue) this is for yours so you can de pin the connection and repin into the black cd changer connection on your radio or cheat and remove the yellow and green plugs from the loom then cut the black connection on the radio and push your remaining blue connection onto the radio.If that makes sense and connect the earth (brown) to the radio (brown) earth lead.
  5. Re: ipod confusion audi models
    #35
    Dec 2008
    Desperately need help!!!
    I've got an A6 S line 2005 model with MMI unit and looking to connect my ipod and really don't mind if I lose single CD player in my glovebox.
    Any help will be greatly appreciated.
    Ron
  6. Re: ipod confusion audi models
    #36
    a5weider Guest
    I have an 08 A5 with no NAV, no aux. Interested in IPOD connection. Will dension work?
  7. Re: ipod confusion audi models
    #37
    May 2007
    knee deep in clunge
    14 Post(s)
    If this is generation 3 radio then no because aux input function isn't supported so you need to retro fit a 2009 radio unit with aux and then change long code bite 11 .Also if the radio is disconnected it will go into component protection.
  8. Re: ipod confusion audi models
    #38
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by hobbie View Post
    Ron
    MMI HIGH or Low
    high colour screen low red screen
  9. Re: ipod confusion audi models
    #39
    a5weider Guest
    Quote Originally Posted by a8 tech View Post
    If this is generation 3 radio then no because aux input function isn't supported so you need to retro fit a 2009 radio unit with aux and then change long code bite 2.Also if the radio is disconnected it will go into component protection.
    is it possible to disconnect the sat input or CD input to use this instead?
  10. Re: ipod confusion audi models
    #40
    May 2007
    knee deep in clunge
    14 Post(s)
    there is no sat input and there is no input for a cd multi player.2008 model radio has no supported software installed to allow external audio source for b8 a4 and a5.
  1. Even Lower Emissions For Latest Audi A4 Petrol And Tdi Models
    Last Post: 14-07-2008, 12:34 PM
  2. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
  3. Further Audi A5 Models Now Released
    Last Post: 25-08-2007, 06:49 PM
  4. Power boost for Audi TT models
    Last Post: 06-08-2005, 07:46 PM
  5. Audi launches efficiency drive with New A6 FSI models
    Last Post: 23-05-2005, 07:34 PM
