Thread: stereo help
  1. stereo help
    Aug 2008
    Scotland
    hello,
    i have just removed the cassette player from my 53reg golf but i have cut wires from the radio that im putting but my problem is that i dont know what wires go to where. the new radio has that written along the wires but i dont know the colour codes for the golfs existing wires.
    can anyone help? please?
  2. Re: stereo help
    Nr Falkirk
    Have you cut the stereo cables or the cables in the car.
    What stereo are you trying to fit?
    Ta Des
  3. Re: stereo help
    Aug 2008
    Scotland
    i cut the cables for the stereo, its an alpine.
    i went to a garage yesterday and they put it in for me but after having use it today i have noticed that
    1. it doesn't automatically go on when i turn the ignition switch
    2. i set up the radio so that it will be set for the radio stations i like, but every time i leave the car and come back after removing the key and lockin the car it forgets the stations i set
    any ideas guys??
  4. Re: stereo help
    Nr Falkirk
    You need to swap the red and yellow wires.
    Different makes of stereo use these differently.
    One is permanently live to allow the stereo to keep the settings stored etc.
    The other is switched to let the stereo to turn on and off with the ignition.
    Sound very much like they have swapped these two around.
    Ta Des
  5. Re: stereo help
    Nov 2006
    Southampton
    Quote Originally Posted by golf7100 View Post
    any ideas guys??
    There are two feeds to your unit, one is a switched +12V feed (which is normally red) and the other is a +12v MEMORY which is normally yellow.
    The switched feed should go to the ignition key whilst the +12V MEMORY wire should normally go to a permanent +12 feed which is there even if the ignition is off.That will ensure your stations are stiil there and it shoud go off when you pull your ignition key out of the lock barrel.
    Hope this helps
    Gazza57
  6. Re: stereo help
    Aug 2008
    Scotland
    thanks to the both of you. i switched the red and yellow wires over and it worked a treat.
  7. Re: stereo help
    Nr Falkirk
    The power of the Internet
    Ta Des
  1. A6 Stereo
    By brian lavell in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-09-2008, 12:31 PM
  2. A3 Stereo
    By TICKDOGG in forum Audi A3 - Archive Topics
    Last Post: 16-05-2008, 11:33 AM
  3. Stereo Dim
    By davegilsenan in forum Golf MK4 - 1999 - 2004
    Last Post: 05-12-2007, 12:23 PM
  4. Help with Stereo
    By Mirx in forum Audi A4 - Archive Topics
    Last Post: 02-05-2007, 07:41 PM
  5. stereo for a4 v6 se '96
    By pintpotter in forum Audi A4 - Archive Topics
    Last Post: 03-02-2007, 03:49 PM
