Thread: 2004 Symphony II - 2008 Concert upgrade...
  1. 2004 Symphony II - 2008 Concert upgrade...
    Mar 2007
    Oxfordshire
    I've just upgraded the Symphony II in my 2004 A3 to a 2008 Concert for the MP3 playing ability. Everything is fine apart from the radio looses signal easily. The 8P A3 works on an amplified aerial system, the Symphony II had a standard aerial connection and a 'diversity' connection (I think it's called). The 2008 Concert has two of these small aerial connections - I had to use an adapter to make the standard aerial fit. What are the two connections on the Symphony II and what are they on the new Concert? How can I make the Concert radio work properly?
  2. Re: 2004 Symphony II - 2008 Concert upgrade...
    May 2008
    You need to change to a dual HF system.
    http://www.kufatec.de/shop/product_i...Sportback.html
  3. Re: 2004 Symphony II - 2008 Concert upgrade...
    Mar 2007
    Oxfordshire
    Thanks for the link - I assume these parts replace the rear antenna amplifiers (one in the boot lid the other abover the parcel shelf)?
  4. Re: 2004 Symphony II - 2008 Concert upgrade...
    May 2008
    Yes they replace your current antenna amps I believe.
  5. Re: 2004 Symphony II - 2008 Concert upgrade...
    Nr Falkirk
    Not sure if this is off topic but do you know if that would also help with poor reception in a Golf.
    I have a Fakre adaptor but the stereo had 2 and I am only using 1 of them
    Ta Des
  1. Question Upgrade A6 Avant Symphony 2 system to a Bose
    By A6Chris in forum In Car Entertainment
    Last Post: 19-08-2008, 10:05 AM
  2. Concert to Symphony 11 Upgrade.....?
    By Tedski in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-03-2008, 07:10 PM
  3. Audi A3 2-Din Concert to Symphony upgrade ?
    By sukrw in forum Archive posts
    Last Post: 23-08-2007, 04:36 PM
  4. Concert/Symphony II + MP3 CD players
    By GeoffT in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-08-2007, 08:39 PM
  5. Swapping Concert I to Symphony I
    By b4gga83 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-07-2007, 12:50 PM
