Thread: Must waterpump be done with cambelt?
Results 1 to 10 of 17
  1. Must waterpump be done with cambelt?
    Aug 2008
    I'm buying a used (04, 60k) 2.0 gt tdi mk5 and have asked the garage (not vw) to sort the cambelt as not been done.
    I'm happy for them to do this work as it is not costing me. I wanted to push for a water pump but did not ask (i seem to recall reading about it on here).
    My question is can i get the water pump done a few months later or does it HAVE to be done at the same time as the cambelt??? If so how much to expect to pay? I'd rather get it done at a later date you see.
    Thanks.
  2. Re: Must waterpump be done with cambelt?
    Same time. Waterpump runs off the cambelt.
    I imagine a new waterpump (make sure it's a brass impellor) will be about £40.
    Get educated or get ripped off!
  3. Re: Must waterpump be done with cambelt?
    Chester-le-Street, United Kingdom
    Quote Originally Posted by tomjj View Post
    Thanks.
    to do the water pump,the cambelt has to be done.
    so if the garage are doing the belt,tell them you will pay for the pump and they can fit it while they are on.
    i believe they are under £50.
    if you wait you will be looking at around £300-£400 if done correctly.
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  4. Re: Must waterpump be done with cambelt?
    Aug 2008
    Thanks - yikes!
    Better get on the phone tomorrow and hope for anything less than £50!
  5. Re: Must waterpump be done with cambelt?
    Aug 2008
    East Anglia, UK
    Quote Originally Posted by STEWY L View Post
    regards,
    stewy.
    Hi, do these have to be done together because of the order they are in?
    I recently had a new water pump on my 3series and of course with a cam-chain it was quite easy. Although i wasn't best please when the water pump bearing went in the first place!
  6. Re: Must waterpump be done with cambelt?
    May 2008
    to clarify, these dont have to be done together, but since the timing belt has to be removed to change the water pump, and most of the cost of the job is labour, it would be a bit daft not to do both together instead of doing the full job twice.
  7. Re: Must waterpump be done with cambelt?
    Aug 2008
    It's ok. I've confirmed it by seeing it with my own eyes so happy it's all being done.
    Unsure if VW parts though.
  8. Re: Must waterpump be done with cambelt?
    Sep 2007
    i'm doing my cambelt soon, i'm not changing the waterpump, unless of course its leaking when i get the belt off the the bearing feels a bit dodgy, my dads passat has got 120k on it, had 2 cambelts but has never had a water pump so unless you want to do it you dont really have to.
  9. Re: Must waterpump be done with cambelt?
    Aug 2008
    East Anglia, UK
    Quote Originally Posted by Torando_golf View Post
    I'd tend to agree, unless it's suspect or really think you want to. If it goes its labour i know. VW just did my cambelt and there was no question to ask if the water pump should be done.
    '08 GOLF GT TDI 140
  10. Re: Must waterpump be done with cambelt?
    Dec 2006
    If you are doing the cam belt the water pump is a MUST in my eyes..
    The water pump impellers tend to fail around 100-120k on average on most vag's due to the plastic impellers..
    Just take a read of my thread here, https://www.vwaudiforum.co.uk/forum/s...ght=water+pump
    The first page, some posts have been removed due to a member requesting this...)
    GO TO PAGE 5 for photos of the work which had to be carried out to change the water pump.... plusa new cambelt while it was in bits..
    Also theres photos of the broke water pump...
    If anyone wants to risk it by not changing it for the sack or around £40.00 thats up to you..
    I know what i will be changing..
    Rick
  1. Noisey waterpump
    By Strutt in forum Golf MK2 - 1984 - 1992
    Last Post: 08-05-2008, 06:21 PM
  2. Is it the waterpump ???
    By hoggy9 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-03-2008, 10:14 PM
  3. audi coupe waterpump
    By mitchcar01 in forum Archive posts
    Last Post: 30-05-2007, 11:25 AM
  4. A4 avant waterpump and cambelt failure
    By michaelahill in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2007, 01:58 AM
