Thread: A6 electroic hand brake
  1. A6 electroic hand brake
    Aug 2008
    Hi im trying to find out how to change the rear pads on a '57' plate A6 s line 2.0 tdi.
    can the motors be turned back using vagcom, and if yes how is it done.
    thanks paul
  2. Re: A6 electroic hand brake
    Dec 2007
    Suffolk
    Have a look here http://wiki.ross-tech.com/index.php/..._Parking_Brake, Very handy website
  3. Re: A6 electroic hand brake
    Aug 2008
    hi yes found that link thanks
    got the instructions in front of me and it says connect battery charger, so once ive opened the calipers it says close controller, once ive done his can i switch laptop off?
    thanks for your help paul
    just found out its a 2006 plate not 57 and itsjust been into audi for rough ideling and they have found that compression gases are blowing past number 3 injector and it needs a new cylinder head. car has only got 40,000 miles on it
  4. Re: A6 electroic hand brake
    Dec 2007
    Suffolk
    once there open and youve clicked close controller you can disconnect the laptop and turn it of, Then reconnect it again when you need to close them.
  5. Re: A6 electroic hand brake
    Aug 2008
    Quote Originally Posted by smokey0123 View Post
    thanks i thought i could do that but just wanted to make sure
    thanks again paul
  6. Re: A6 electroic hand brake
    Aug 2008
    Quote Originally Posted by saabsalltheway! View Post
    thanks again paul
    Thanks everyone
    i cant beleive how easy it was to fit the rear pads after using vag com to set the hand brake motors.
    thanks again for your help
    paul
  7. Re: A6 electroic hand brake
    Dec 2007
    Suffolk
    No problem, pleased we could help you
  1. help at hand
    By skinner in forum General Detailing/Cleaning Questions
    Last Post: 03-02-2008, 02:51 AM
  2. SKC Code for second hand car
    By Cohen Fain in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-11-2007, 03:40 AM
  3. hand brake light on
    By gpaul in forum Vento - 1994 - 1998
    Last Post: 07-11-2007, 10:35 AM
  4. Hand Brake Performance - 1995 Mk3 Gti 16v
    By dravidham in forum Golf MK3 - 1993 - 1999
    Last Post: 21-09-2007, 08:57 PM
  5. BRAKES (Electronic hand brake)
    By trident in forum Passat - Archive Topics
    Last Post: 10-10-2006, 09:54 AM
