Thread: Some advice please for a new member
  1. Some advice please for a new member
    Aug 2008
    I am considering buying an A4 2.5 tdi automatic, 105,000 miles, year 2000 with a full service history. Do you think it is likely to give lots of trouble and what are the weaknesses? I would appreciate all responses. Thanks, Leonard
  2. Re: Some advice please for a new member
    Jul 2007
    Cheshire, or my A6
    First, it depends what auto box the car has. There is usually Tiptronic and Multitronic (CVT) and the CVT boxes tend to give trouble. However I don't think the CVT boxes were available in 2000 (but I could be wrong !) so you may not have to worry there.
    The Audi engines tend to be very strong, I wouldn't worry too much about the engine itself if it has been serviced regularly.
    Try and take it around a car park and do a few left to rights and look for clunks from the front suspension, as a typical Audi points all the weight over the front and that can cause worn CV joints and stuff.
    On my A6, there was an alternator bearing problem. It may not apply to 2000 A4s but you could check anyway. While stationary, turn to full lock either way and listen out for any sort of screech, clatter or any of the sort. If so, it will need a new alternator bearing with the part costing about £70 from Audi, plus labour.
    Paul
  3. Re: Some advice please for a new member
    Aug 2008
    Thanks for prompt reply. What MPG do you think I can expect for short stop/start journeys? Also, do you think 105,000 miles is too much?
  4. Re: Some advice please for a new member
    Aug 2008
  5. Re: Some advice please for a new member
    Jul 2007
    Cheshire, or my A6
    105,000 should be fine for an Audi diesel.
    MPG... I would expect about 30 ish to be honest. Maybe a little more... but if MPG is your thing then you may be best looking at a 1.9 TDI.
    Paul
  1. New member seeks advice
    By duttonbrian2 in forum New Member Introductions
    Last Post: 28-06-2008, 01:37 AM
  2. New member looking for wheel advice
    By s21deg in forum Golf MK5 - 2004 - 2009
    Last Post: 26-12-2007, 02:41 PM
  3. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  4. New member - wants some advice
    By rhanney in forum New Member Introductions
    Last Post: 19-06-2007, 09:11 AM
  5. Buying S3 Advice new member
    By olliea in forum New Member Introductions
    Last Post: 12-03-2007, 11:47 PM
