Thread: Rear tyre wear - A4 cab.
  1. Rear tyre wear - A4 cab.
    May 2008
    Hi all, I've got a 2005 2.5TDI cab which I bought 3 months ago. The rear n/s tyre had a fair bit of wear just on the outer 2" or so. Since then I've done another 4000 miles and now it's nearly bald. I've no idea if the rear wheels have been rotated from the fronts and this tyre had a bit more wear to begin with (perhaps due to steering misalignment). All the other tyres have even tread wear accros their surface.
    Now there are no handling issues that I'm aware of, so can should I just buy a new tyre, or might something sinister be at work here that needs to be checked?
  2. Re: Rear tyre wear - A4 cab.
    Bournemouth
    does the rest of the worn tyre look like it has worn evenly since you noticed the outer wear when you bought the car? this might indicate that it has been rotated.
    you could go and have the suspension checked out, and get a 4 wheel tracking done? good place to start i would think.
  3. Re: Rear tyre wear - A4 cab.
    May 2008
    The wear does look even. I was going to take it to a local tyre fitter but I'm not sure I could trust them to do any form of 4 wheel tracking. The car has an Audi warranty, but then again, last time I tried to invoke it I still got charged for diagnostics.
  4. Re: Rear tyre wear - A4 cab.
    Bournemouth
    there shouldnt be any diagnostics fee invoved in this if you take it back
  5. Re: Rear tyre wear - A4 cab.
    Bournemouth
    how ironic i now seem to have the same problem on mine
    getting a new tyre and a 4 wheel track done....
  6. Re: Rear tyre wear - A4 cab.
    Bournemouth
    got 2 new rear tyres (falken fk452) and a four wheel track, the rears were aiming slightly to the left of the thrust angle of the front wheels, therefore increasing wear on the outside of the rear drivers wheel.
    the tracking is now spot on, and the car drives much better, its even sorted out the wheel wobble i had when doing erm, over 69mph
  1. A4 2.0 TDI SE Tyre wear
    By marcus in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-05-2009, 10:06 PM
  2. Rear Tyre wear Issue...Proof Required
    By andy4976 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-08-2008, 10:29 PM
  3. Un-even tyre wear......
    By bora(ing) nick in forum Chat - Anything with wheels
    Last Post: 04-10-2007, 02:45 PM
  4. Tyre wear
    By Eclipse car Audio in forum Audi A4 - Archive Topics
    Last Post: 07-03-2007, 12:52 PM
  5. VW Passat Rear Brake & Tyre Wear
    By VWItaliano in forum Archive posts
    Last Post: 23-10-2006, 12:20 PM
