Thread: Vento Diesel Suddenly Dropping power
  1. Vento Diesel Suddenly Dropping power
    Aug 2008
    Hi All,
    I have like to work on my cars instead of taking to a garage. Now I have a problem with my partner's car which is a VW Vento 1.9 TDi.
    The problem I have is you can drive the car normally not a problem but all of a suddern you get a drop in power where the turbo kicks in. I have spoken to someone (but can not remember who) and one thing they said try when this happens is turn the engine off and back on - when doing this the power comes back for a bit and then drops off.
    The question is - what is doing this and how do I sort it?
    Any help on this would be much appricated as this is the first car I have worked on that is diesel, has a turbo and has injectors.
  2. Re: Vento Diesel Suddenly Dropping power
    Belgrade,Serbia
    the problem as you describe it should be the vanes on the turbo. that is known problem on vw. they get dirty and then tend to stick so the ecu shuts the turbo off to prevent it from overcharging. it would help to know what year is the car and what is the engine code. the three letters before engine number
  3. Red face Re: Vento Diesel Suddenly Dropping power
    Aug 2008
    Hi TDi Miki,
    Thank you for your reply, the Vento is 1997 R Reg.
    The Engine code is AHU.
    What you hve decribed makes sense, I must admit I first thought it might be a alve opening to release the pressure and not closing.
    How do I go about cleaning them? Is it a matter of taking the turbo off and blowing clean with an air line or is there something else I need to do?
    Thank you for your help in advance.
  1. V-Power Diesel
    By stewartt997 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-07-2008, 08:54 AM
  2. Fault with glow plugs on 1995 diesel vento
    By ManiacMunz in forum Vento - 1994 - 1998
    Last Post: 22-02-2008, 06:22 PM
  3. Loss of power suddenly - A4 1.9 TDI 1998
    By Steve Foster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-01-2008, 12:30 AM
  4. '95 golf 1.8 Driver - power/rev dropping
    By Dollso in forum Golf MK3 - 1993 - 1999
    Last Post: 16-11-2007, 05:47 PM
  5. v-power diesel
    By golfmark5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-06-2007, 01:22 AM
