Thread: 01316 Airbag Fault Code
  1. 01316 Airbag Fault Code
    Angus, Scotland
    Hi Guys,
    Just done a VCDS Scan on the car to see if there were any fault codes that may relate to my cars inability to start on the button each morning but there were none that may affect that, but I did get a couple:
    One is an alarm via tilt sensor which i'm not too worried about but the other is to do with the airbag which I am a touch more concerned about.
    See my auto scan below:
    Sunday,10,August,2008,17:25:50:02832
    VCDS Version: Release 805.0
    Data version: 20080529
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E85Axxxxxx Mileage: 82780km/51437miles
    Address 01: Engine Labels: 03G-906-016-BLB.lbl
    Part No SW: 03G 906 016 GN HW: 028 101 211 3
    Component: R4 2,0L EDC G000SG 9618
    Revision: 12345678 Serial number:
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
    Component: ESP8 front H04 0180
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004401
    Shop #: WSC 06335 000 00000
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AM
    Component: A4 Klimaautomat 2728
    Coding: 00000
    Shop #: WSC 06335
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 H
    Component: int. Lastmodul ECE 0303
    Coding: 00001
    Shop #: WSC 00861
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H10 3230
    Revision: 91H10323 Serial number: 0036M000ULRN
    Coding: 0033622
    1 Fault Found:
    01316 - ABS Control Module
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 99
    Time Indication: 0
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 01041
    Shop #: WSC 00000
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 950 S HW: 8E0 920 950 S
    Component: KOMBI+WFS 4 H12 0030
    Revision: 0030 Serial number: 00000000000000
    Coding: 0004444
    Shop #: WSC 00861 210 63874
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BM
    Component: Komfortgerát T3B 2431
    Coding: 06395
    Shop #: WSC 06335
    Part No: 8E2959802B
    Component: Tőrsteuer.FS BRM 0205
    Part No: 8E2959801B
    Component: Tőrsteuer.BF BRM 0205
    Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0205
    Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0205
    1 Fault Found:
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 M
    Component: symphony II PM6 0410
    Coding: 01201
    Shop #: WSC 00768
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 B HW: 8E0 919 283 B
    Component: Parkhilfe 4-Kan H06 0020
    Revision: 00H06000 Serial number: 00067802030433
    Coding: 0000104
    Shop #: WSC 131071 1023 2097151
    Any help regarding this would be appreciated. Not sure if it is related but VCDS will only connect to Module 45 intermittently, as you can see by the above scan it didn't this time, but when I went in through the module itself it did connect, then it wouldn't then it did again!! Hope it's not some sort of diagnostic wriring problem!!
    Cheers for the help in advance guys
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  2. Re: 01316 Airbag Fault Code
    Angus, Scotland
    Hi guys,
    Any ideas???
    Paul
  3. Re: 01316 Airbag Fault Code
    May 2008
    see here the ross-tech wiki says 01316 is an ABS problem.
    Try clearing it and re-check the comms status with the controller.
  1. Replies: 13
    Last Post: 25-10-2010, 01:38 PM
  2. Airbag Fault!
    By vw754 in forum VCDS - General Questions
    Last Post: 24-10-2008, 07:14 PM
  3. code 01217 driverside airbag
    By knothead6666 in forum Chat - Anything with wheels
    Last Post: 28-04-2008, 10:45 AM
  4. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
