Thread: How to fit MAIN headlight bulbs?
Results 1 to 8 of 8
  1. Red face How to fit MAIN headlight bulbs?
    2004 Estate Highline TDi PD - 130
    I've fitted the 'dipped' headlights with Super Brilliance Xenon H7 bulbs
    from Halfords.
    No problem.
    However the 'main' beam bulbs are posing a problem.
    Does anyone know how to fit these?
    I've removed the black egg shape hard plastic cover. Even with a mirror it is hard to see, but it looks like there are two brass Torx bolts (star shape), do these have to come off? (I'll have to buy a set! )
    If so, do you then turn the bulb housing anti clockwise?
    I ask because I do not want to put undue pressure on the housing.
    If it's stubborn I can turn hard with confidence.
    I've seen the link that others have posted about how to fit - this link
    DOES NOT show how to fit the main beam.
    I've Googled - no joy anywhere.
    Any help would really be appreciated.
    Thanks in advance.
    Stephen
  2. Re: How to fit MAIN headlight bulbs?
    Jun 2006
    UK, Mids
    I did mine, but struggle to remember, but there were no screws of any type. I think you remember which way up the bulb/holder is, turn the bulb holder 1/3rd of a turn and withdraw it. You then can take the bulb out. Does this sound right? Putting it back is harder, make sure it is not a 1/3rd of a turn out when offering back up as it will go in, but be crooked and jam.
    Audi A8 - 2015 - 3.0TDI
  3. Re: How to fit MAIN headlight bulbs?
    Kinross Scotland
    If you follow this link and copy the pdf then you will have the full instructions plus photographs
    http://home.comcast.net/~slashpub/he...lightBulbs.pdf
    Regards Richard
  4. Re: How to fit MAIN headlight bulbs?
    Thanks Snapdragon and Richard.
    Unfortunately, the pdf link doesn't cover the 2004 - it's similar, but the picture shows a light grey plastic 'grip' holder - mine does not.
    I'll have to order a Torx set and go for it.
  5. Re: How to fit MAIN headlight bulbs?
    Kinross Scotland
    If you post your car details and engine code i will look in elsawin for you and PM the details to you.
    Regards Richard
  6. Re: How to fit MAIN headlight bulbs?
    Jun 2006
    UK, Mids
    Quote Originally Posted by TeaTimeGilly View Post
    The PDF is similar to mine, but there is another big thing in the main beam aperture with Y-shaped raised ridges in the pdf, this is not on mine, so must be because it has american marker lights or something.
    My main beam is like the picture reflected in the CD, a square holder that you can feel, but not see so easily. I am surprised if the 2004 is different as it looks identical from the front and is sold 2000-2005 in parts lists. e.g.
    http://www.carlamp.com/cart/view_pro...46/0&view=back
  7. Thumbs up Re: How to fit MAIN headlight bulbs?
    Jun 2008
    Hi Just a quick tip when you finally suss out how to fit your replacement bulbs and the retaining clip do not push too hard when you insert the bulb.
    It is possible to actually detach the whole adjustable light unit from the main housing and once this happens you then have to replace the whole headlight. I did this myself on my last passat trying to fit the retaining clip and its nearly impossible to refit the two assemblies.
    Its just a warning be patient and take your time.
    If it ain't broke leave it alone!!!
  8. Re: How to fit MAIN headlight bulbs?
    Jun 2006
    UK, Mids
    Good tip, very true, seems to affect all similar Hella headlights, e.g. Vauxhalls, not a VW Problem, but Hella.
  1. Headlight Bulbs
    By james_tiger_woo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-01-2009, 04:10 PM
  2. Changing headlight bulbs
    By Stuart W in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2008, 06:06 AM
  3. Headlight Bulbs
    By Michelin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 02:42 AM
  4. Headlight Bulbs - Main Beam
    By Ben in forum Chat - Anything with wheels
    Last Post: 11-12-2007, 10:16 PM
  5. Dipped to main beam headlight problem
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2007, 09:05 AM
