Thread: vag.com error code P1245
  1. vag.com error code P1245
    Jun 2008
    hi
    I own a t4 2.5 transporter and error code P1245 is coming up, could anyone tell me what this relates to and how to cure the error
    thanks
  2. Re: vag.com error code P1245
    Dec 2007
    Sheffield
    According to the internet the error code is this: DTC P1245 Intake Plenum Switchover Valve
    Not sure what it is though maybe someone else can expand
  3. Re: vag.com error code P1245
    Ambler, PA, USA
    Another internet source claims: P1245 Needle Lift Sensor Short To Ground
    I also am unable to help further.
  4. Re: vag.com error code P1245
    Jun 2008
    hi
    the error is P1245 Needle Lift Sensor Short To Ground:- but I am struggling to find what this refers to in lay mans terms
    thanks
  5. Re: vag.com error code P1245
    injector number5, it the one on the right as you look in,has a wire coming off it and it's shorting to ground ie the engine block or something
    so you need to trace the wire and look for holes in the insulation ect. make sure the contact on the injector is clean, no oil or water.
    if you take off the front grill and undo some bolts (1 13mm on each side and 2 10 mm on the intercooler if you have one) you can lift the rad up and out towards you using the handle in the middle this makes it easyer to look around
    tracing electrical problems are a nightmare
  6. Smile Re: vag.com error code P1245
    Jun 2008
    thanks, very much appreciated
  7. Re: vag.com error code P1245
    Magdeburg, Germany
    Quote Originally Posted by bearthebruce View Post
    Let me help you out.
    VCDS would say Needle Lift Sensor (G80): Short to Ground, I added some additional information to our WIKI.
    Sebastian @ www.Ross-Tech.com
  1. P1476 error code
    By Dezzed in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-07-2008, 10:42 PM
  2. Question error code
    By mark53 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-07-2008, 10:22 PM
  3. Error code reader - VAG COM?
    By brauser rexel in forum Archive posts
    Last Post: 16-09-2007, 04:07 PM
  4. VAG COM Error Code
    By rachykate in forum VCDS - General Questions
    Last Post: 04-04-2007, 10:19 AM
  5. OBD - Error Code Anyone know what this is
    By triman in forum Audi A4 - Archive Topics
    Last Post: 03-02-2007, 06:10 PM
