Thread: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
  1. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #21
    1840 Post(s)
    18051 (P1643) Check DTC Memory of Electric Load Controller
    Check the Central Electrics unit 09 for fault codes.
  2. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #22
    May 2008
    I've checked for a fault code and got 01598-drive battery voltage
    Not sure what it means or if its relevant.
    Anyway,
    From what I can gather, the fans (both) run on a slower speed when the air con is in use and a higher speed if the engine over heats.
    As my fans are running on a low speed (and I changed the radiator fan sensor) I'm tending to rule out that side of things and think that maybe something in the air con system is switching them on. I just need to find out what else (apart from switching on the air con) could be starting the fans ?
    Dave
  3. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #23
    1840 Post(s)
    Drive battery voltage is the battery voltage itself. Scan the HVAC for codes.
  4. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #24
    May 2008
    Yes I've scanned the HVAC, no fault codes.
  5. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #25
    May 2008
    Hello,
    I want to swap my Air con conrol unit, from my VW Touran, part Number 1T2 820 045, with one from a VW Golf MK5, part number 1K2 820 045. Would this swap be OK and if so will the replacement controller need coding ?
    Thanks, Dave
  6. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #26
    1840 Post(s)
    1T2 820 045 is not a good number but 1K2 820 045 changed to 1K2 820 045 B and it only fits the Eos, Golf 5 and Jetta 5. That part number is only for the trim though, not for the controls. I think you need 1K0 820 047 FT WHS but that is only a guess and is a new number, the original has changed part number the times so must have been giving trouble, making the fans run maybe?
  7. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #27
    May 2008
    Hi Crasher,
    Thanks for your reply, yes I gave the wrong number I'm pretty sure its
    1T2 820 047CB (but it could be 1K2 820 047CB) So would the later
    1K2 820 047B 'work' on the Touran? Its from a breakers and is the nearest part number I could find.
    I'm looking at the air con side and thought that replacing the control module would rule it out, as I can't really see what else would trigger the fans?? I'm starting to get a bit desperate! and fed up with it!!!!
    Dave
  8. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #28
    1840 Post(s)
    1T2 820 047 CB isn’t a good number either.
  9. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #29
    May 2008
    Hi Crasher,
    I've checked the part number on the module and thats whats written on it,
    But the part number thats displayed using vag com for the module is
    1K0 820 047CB
    Dave
  10. Re: Radiator cooling fan problem? - Crasher/a8 tech - can you help?
    #30
    1840 Post(s)
    1K0 820 047CB is 1K0 820 047 B REH which changed to;
    1K0 820 047 CR REH
    1K0 820 047 EF REH
    1K0 820 047 DF REH
    1K0 820 047 DP REH
    1K0 820 047 FH WHS
    1K0 820 047 GK WHS
    1K0 820 047 FT WHS
    Frankly I have never seen a part change number so many times in such a short time.
  1. 1.8T oil (eliminate sludging) crasher or a8 tech.
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-07-2008, 12:50 PM
  2. Please Help s3 cooling fan problem
    By Biksta in forum Audi A3 - Archive Topics
    Last Post: 09-06-2008, 04:02 PM
  3. Crasher can you help? mk3 TDi problem
    By chackday in forum Golf MK3 - 1993 - 1999
    Last Post: 08-05-2008, 08:50 PM
  4. A3 Cooling Fan Problem
    By MOTOW in forum Audi A3 - Archive Topics
    Last Post: 10-10-2007, 09:05 PM
  5. Sharan - radiator cooling fan stays on & drains battery
    By BobDavies in forum Touran - Sharan - Caravelle
    Last Post: 28-01-2007, 10:41 PM
