Thread: airbag error code will not reset. How do I fix *driver side resistance too low*
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: airbag error code will not reset. How do I fix *driver side resistance too low*
    Norfolk
    Just a general comment. You cannot diagnose an air bag problem by disconnecting the air bag. The air bag can be faulty in two different ways, open circuit or short circuit. Since both faults could be in the wires to the air bag, disconnecting the air bag tells you nothing. Substituting a "good" airbag or a known resistance will tell you if the wires or the airbag are faulty. REMEMBER - AIRBAGS CAN BE DANGEROUS!!!
  2. Re: airbag error code will not reset. How do I fix *driver side resistance too low*
    Feb 2009
    Thanks for everyones feedback.
    Since this is my 16 year old daughters VW Beetle that has the side airbag fault, I guess I need to bite the bullet and take it in for repair.
    As you said, airbags van be dangerous.
    I'll let the forum know the outcome of the repair
  3. Re: airbag error code will not reset. How do I fix *driver side resistance too low*
    Oct 2009
    Timisoara
    interesting
  4. Re: airbag error code will not reset. How do I fix *driver side resistance too low*
    Oct 2010
    Columbus, IN
    Quick question about the heat shrink on the wires (I saw on the flickr picture that you had 3 wires on your airbag (older model) as I do)
    -How did you re-wire the wires? (Brown to brown, white and brown to brown, etc). I don't exactly want to just wire according to location, as I don't exactly feel like buying a new airbag due to stupidity.
  1. Oil leak from driver side
    By Abuabida in forum Bora - 1998 - 2005
    Last Post: 07-04-2017, 08:51 PM
  2. airbag fault reset
    By bora185 in forum VCDS - General Questions
    Last Post: 12-03-2009, 11:48 PM
  3. how do you reset airbag light?
    By riz_bhatti in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-05-2008, 03:37 PM
  4. Airbag light reset?
    By VtecJunkie in forum Audi A4 - Archive Topics
    Last Post: 01-02-2008, 12:12 AM
  5. A6 airbag ECU reset
    By gale007 in forum Chat - Anything with wheels
    Last Post: 14-09-2007, 11:56 AM
