Thread: Reading Air/Fuel ratio with vagcom. HOW?
  1. Reading Air/Fuel ratio with vagcom. HOW?
    Jun 2008
    Does anyone know how to read air fuel ratio with the vagcom for the A4 1.8T?
    Would like to check if car is running rich as fuel consumption is awful at 23mpg or so.
    Many thanks.
    J
  2. Re: Reading Air/Fuel ratio with vagcom. HOW?
    Jul 2007
    Near Maidstone, Kent
    Generally blocks 30, 31 and 31 are used to determine A/F mixture.
    Have a look at 31 first. That will give you the Lambda values around 1.
    Lambda of >1 is Lean
    Lambda of <1 is Rich
    A/F ratio = Lambda x 14.7
    Have a read of this too. It will give you an idea of what you should see.
    http://www.ross-tech.com/vag-com/cars/fuel-trim.html
    Hope this helps.
  1. outside temperature reading '- - -'
    By abble in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2008, 10:17 AM
  2. fuel gauge reading
    By surgey in forum Audi A3 - Archive Topics
    Last Post: 22-04-2008, 03:45 PM
  3. a4 tdi fuel gauge constantly reading full
    By a4Rob in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-04-2008, 10:20 PM
  4. Bora TDI Fuel gauge reading full
    By cubby in forum Bora - 1998 - 2005
    Last Post: 07-06-2006, 10:17 AM
  5. Bora Fuel gauge reading full on empty tank
    Last Post: 06-06-2006, 06:15 PM
