Thread: CD Stuck in VW RCD300
  1. CD Stuck in VW RCD300
    May 2008
    Berks
    i have somehow managed to get a CD to stuck in my CD player (VW RCD300). Its just not coming outtt...
    Any idea how to force it out?
    My passat is still under 3 yr Manuf warranty, so is taking it to dealer an option? (I am not sure if the warranty cover these thins)
    Many Thanks
    WH
    _________________________________
    Pearl Black - B6 Sports | 17" Monte Carlo
    & I m lovin it...
  2. Re: CD Stuck in VW RCD300
    May 2008
    Surrey, UK
    Quote Originally Posted by wh431 View Post
    Many Thanks
    WH
    Warranty should cover it, if not at least a goodwill gesture from the dealer might be in order.
    One thing I often find with some navigation units is there is a build up of grease on the roller eject mechanism. This causes the roller not to grip the disk when ejecting. what I advise in those instances is to get a blunt cutlery knife and carefully insert it into the CD slot so it goes in above the disk. Just about an inch ontop of the disk itself is enough. then pressing down gently on the disk itself, press the eject button.
    Hope this helps.
  3. Re: CD Stuck in VW RCD300
    Apr 2009
    Ireland
    Unfortunately my car is out of warranty and the eject button (RCD 300) is starting to stick in and not ejecting the cd anymore. Has anyone come across this before and is there a quick fix? Or is it a money maker for the dealer?
  4. Re: CD Stuck in VW RCD300
    Jul 2008
    WH
    I had a similar problem with my RCD500, and as the car was only 2 years old it was covered by warranty. They replaced the unit with a new one, so take it to the dealer.
    I've heard of people fixing it themselves by taking the unit apart, but not worth it if covered by warranty.
  5. Re: CD Stuck in VW RCD300
    Jul 2016
    Quote Originally Posted by mhurer View Post
    Having removed the unit from my VW Touran and tried all sorts of tricks, this fixed it for me:
    How to remove a CD that is stuck in RCD300 - YouTube
  1. About RCD300
    By stoyankolev in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-02-2008, 12:43 PM
  2. Can you connect a sub to rcd300
    By s21deg in forum Golf MK5 - 2004 - 2009
    Last Post: 15-12-2007, 04:21 PM
  3. Vw Golf Mk5 Rcd300 Cd Player
    By TANKSTER in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-06-2007, 03:27 AM
  4. RCD300 in a B5.5
    By NickW in forum Passat - Archive Topics
    Last Post: 30-03-2007, 03:36 PM
  5. RCD300 convert for MP3?
    By PASSATPILOT in forum Passat - Archive Topics
    Last Post: 18-02-2007, 04:27 PM
