Thread: Sharan fuse blows
Results 1 to 10 of 13
  1. Sharan fuse blows
    Jul 2008
    I have an 04 Sharan on a 53 plate. 80k miles 1.9 TDi PD
    Yesterday morning I drove 200 miles or so with no problem. Then in the afternoon I got back in the car and I had no speedo or indicators. The ABS light was on and the brake warning light flashes. I found that fuse #3 was blown so I replaced it (with another 5A fuse) with blew as soon as I switched on the ignition.
    Looking at the fuse card, there appears to be a lot of equipment 'hung' off of this fuse so my 1st question is should this fuse really be 5A (not 25).
    My 2nd question assuming I am not trying to replace a seriously underrated fuse is has anybody come across a similar problem on a VW as this?
    F.Y.I. The horn doesn't work (my fuse card says it's on a completely different fuse). The rear heater doesn't work, neither does the AC or air recirculation. I have taken out the dash pod (removed the 2 connectors to isolate), I have dis-connected the indicators at the stalk, I have isolated the AC switch, recirculation switch and the rear heater switch, but the fuse still blows. I have also isolated the ABS servo (just in case).
    It’s not a problem with an indicator bulb as the hazards still work, as do all of the other lights.
    Theres not much I haven't dis-connected but there is obviously something I'm missing. What?
  2. Re: Sharan fuse blows
    Chester-le-Street, United Kingdom
    Quote Originally Posted by gadcam View Post
    in all honesty,in times like this,i feel your best option would be to take it to a reliable independant garage. they have much more experience/diagnostic
    ability to source the problem quickly. their are good ones out there who won't take your eyes out,and you will come away with the car being the way it should be,without loosing the hair line
    it could be anything,leave it to the experts,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Sharan fuse blows
    Jul 2008
    Yep, it spent most of yesterday in my regular independent garage. They spoke to 2 vehicle electricians (one came to see if he could find the fault) but no joy.
    I have now booked it in with my local dealership to see if they can sort it without me having to re-mortgage
  4. Re: Sharan fuse blows
    Here is a list which fuse 3 is connected with,as you see the horn is included E94 - Heated driver seat regulator
    E95 - Heated front passenger seat regulator
    E109 - Multifunction display memory switch
    E256 - TCS and ESP button
    F36 - Clutch pedal switch (only models with manual gearbox)
    F47 - CCS brake pedal switch
    F138 - Airbag coil connector
    G85 - Steering angle sender
    H - Horn plate
    J4 - Dual tone horn relay
    J104 - ABS/ABS with EDL/TCS/ESP control unit
    Y2 - Digital clock
    J162 - Heater control unit D5W Z
    J220 - Motronic control unit
    J255 - Climatronic control unit
    J301 - Air conditioning system control unit
    J453 - Multifunction steering wheel control unit
    J501 - Multifunction unit control unit
    J503 - Control unit with display for radio and navigation syst
  5. Re: Sharan fuse blows
    Oct 2010
    cheltenham
    hi can u tell me the final outcome of your problem with fuse 3 blowing on your sharan as mine is doing exact same thing
    cheers rob
  6. Re: Sharan fuse blows
    Nov 2008
    folkestone.kent
    i have just had a quick look through a wiring diagram and that fuse also feeds the number plate lights......only a guess but check the wiring in the tailgate ...........
    according to my wiring diagram the horn is fed from fuse s6 25 amp and not fuse s3 5 amp
  7. Re: Sharan fuse blows
    Oct 2010
    cheltenham
    ok thanks will take a look and will leave feedback
  8. Re: Sharan fuse blows
    Jun 2012
    Chester
    Hi There,
    I'm new to this forum. Have had a 2003 (53) Sharan Carat 130bhp for a few months now.
    I have been having this exact same problem. Did anybody find a solution for it please?
    Thanks for any advice.
    John
  9. Re: Sharan fuse blows
    Feb 2017
    United Kingdom
    Hey did you ever find the fault please as ours is doing exactly the same.
  10. Re: Sharan fuse blows
    Feb 2017
    United Kingdom
    Hi did you get yours sorted? What was the problem please as ours is doing the exact same.
  1. fuse 12
    By davemcg in forum 80 - 90
    Last Post: 29-05-2008, 10:41 PM
  2. Sharan Fuse box (2nd Plea for help !!)
    By tonyerc in forum Touran - Sharan - Caravelle
    Last Post: 18-03-2008, 06:15 PM
  3. Mk4 Golf, Heater only Blows cold air!!!
    By nobby999 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-09-2007, 02:29 PM
  4. TDi Engine hose blows off at 3000rpm!
    By DaveJB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 12:47 AM
  5. 2006 Climatic Problems - Blows Cold, but cabin hot?
    By longboyad in forum Passat - Archive Topics
    Last Post: 17-07-2006, 08:51 PM
