Thread: Polo 1.4 TDI Engine Management
  1. Polo 1.4 TDI Engine Management
    Jul 2008
    I have a 54 Plate Polo 1.4 TDI 3 door.
    Problem: Every so often the Engine Management warning light comes on and the engine loses power at the top end .
    The problem usually disappears once the ignition has been switched off and the car has been left for a while, sometimes longer than others.
    Garage ran it through diagnostics and mechanic took it for a test drive but found no evidence of a fault.
    Does anyone have any ideas or has anyone experienced the same problem?
  2. Re: Polo 1.4 TDI Engine Management
    Mar 2008
    Hi!
    Tried changing the Air Mass Meter? Alot of cars with TDI engines are experiencing the same kind of problem. It seems to be especially common on 98-02 models.
    e.g take a look in the upper most section here for some statements:
    http://www.wak-tt.com/vagcom/vagcomamm.htm
  3. Re: Polo 1.4 TDI Engine Management
    Nov 2008
    I Have The Same Problem !!! My Polo 1.4 Tdi Has Been Re-mapped. Works Fine For A While, Then The Turbo Cuts Out. Turn Ignition Immediatley On / Off And It Works Fine Again.
  4. Re: Polo 1.4 TDI Engine Management
    Mar 2008
    My '03 Polo Playa 1.4Tdi does the same thing but only when it's still cold and while putting a lot of power down like on an uphill climb. Tell you what, it is dead as a doornail then!!
    It must have something to do with the turbo being starved of oil as it's still cold...
  5. Re: Polo 1.4 TDI Engine Management
    Feb 2007
    Quote Originally Posted by mrsteady99 View Post
    When this fault occurs does it feel like the car is running rough i.e only running on 2 cylinders???
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  1. Question engine management
    By mick1 in forum Bora - 1998 - 2005
    Last Post: 21-05-2008, 08:47 PM
  2. engine management
    By nicho in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-02-2008, 09:15 PM
  3. VW Polo 1.4 auto 2000 Engine management light probs
    By M'lady in forum Polo - Derby - Lupo - Fox
    Last Post: 06-12-2007, 03:16 PM
  4. a2 engine management
    By geraint in forum A2
    Last Post: 29-07-2007, 10:21 PM
  5. Polo 1.2 Engine management warning light
    By Polodout in forum Polo - Derby - Lupo - Fox
    Last Post: 20-07-2007, 10:20 AM
