Thread: Front Windscreen Washers.
  1. Front Windscreen Washers.
    Sep 2007
    North Wales
    Hi.
    How do I remove the front Windscreen Washers? The one on the drivers side is really hacking me off as it is very low. I have tried putting pins in it and it still doesn't work properly. The one on the passenger side is great, so I'd like to swap them over and maybe have a really good go at clearing the jet.
    Many thanks.
  2. Re: Front Windscreen Washers.
    Gwent
    You could try using a syringe to suck the debris out of the jet.
    If you really need to remove the jet there is a 'tab' at the back of the jet, this needs to be bent forward to release the back edge which lifts out first. Not easy to do, because the hole under the jet is too far forward!
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Audi A4 Front windscreen heater
    By amo_bains in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-11-2013, 01:45 PM
  2. Question Sensor type thing on front windscreen
    By kurtas2006 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-07-2008, 10:08 PM
  3. Headlight & windscreen washers
    By noddy1875 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-07-2008, 12:39 AM
  4. Audi A4 Front Windscreen Heater
    Last Post: 13-02-2008, 03:20 PM
  5. Sharan front heated windscreen
    By montymole in forum Touran - Sharan - Caravelle
    Last Post: 07-12-2007, 12:03 AM
