Thread: Rear Electric window problem
  1. Rear Electric window problem
    Jul 2008
    The rear window on my 1995 Passat Saloon has stopped working. Before it totally packed up it would very intermittently go down by itself when starting the car up.
    I have put a brand new (VW PART) motor in and connected it up but still no joy, There is a black electrical connector box which I have also replaced but the window does not work. The Heynes manual says that there is a thermal cut out switch - is this in this balck connector box or is it somewhere else that i am not looking. If anyone else has experience in this matter i would be eternally grateful as it may stop me pulling my hair out!!!
  2. Re: Rear Electric window problem
    Jul 2008
    Check that the wires are not damaged as the pass from the door to the car body. They are inside the rubber gaiter, this peels back easily and you will probably find one or more of these wires broken. Just repair these with some electrical connectors. Job done!
  3. Re: Rear Electric window problem
    Jul 2008
    I told my friend what you said & he tried it & hey presto the window wire had a split in! A quick solder & it is working as good as new!! Thanks very much! Now got to see if the dealer will take the electric mechanism part back for a refund!!
  1. electric rear window not working
    By scouserfax in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2008, 01:35 PM
  2. Rear electric window not working
    By SteveX in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-05-2008, 06:27 AM
  3. Golf GTI Rear electric window problem
    By dezza in forum Golf MK3 - 1993 - 1999
    Last Post: 06-02-2008, 05:00 PM
  4. rear electric window on mk3 gti...
    By alex dubz in forum Golf MK3 - 1993 - 1999
    Last Post: 29-11-2007, 04:30 PM
  5. Electric window problem!
    By HappyS3Owner in forum Audi A3 - Archive Topics
    Last Post: 02-08-2007, 04:57 PM
