Thread: tips and tricks for golf mk5's
  1. tips and tricks for golf mk5's
    Coventry
    These, in no particular order, may work on your golf mk5 depending on the spec. some may work on other models e.g. touareg
    Remote Window Closure / Opening
    After leaving the car, press the 'lock' on the remote, and keep it held down (on)....the windows and sunroof will close (only whilst you hold the remote button)
    Conversely, pressing the 'unlock' on the remote, and keeping it held down will open the windows (but not sunroof)
    Release the remote when they are at desired position!
    Service due reminder
    It's all about the trpi-reset, button, with the ignition on, let the seatbelt alarm go off (if you're not wearing it) preferably wear the seatbelt and within 2 seconds of turning the key to light up the ignition lights, (do not start engine) press and hold the trip-reset button. You will NOT lose the trip count - it'll go to zero initially, show you the mileage to the next service interval, and the trip counter will go back to what it was.
    The display resets back to the normal computer after about 30 secs.
    Windscreen Wiper Access
    The windscreen wipers are neatly tucked away when not in use for aerodynamics and safety.
    To clean under them or change the blades is easy!
    With the ignition key in 'off' position or removed, pull the wiper stalk down momentarily.
    The wipers will wipe to 12 o'clock position and remain in that position.
    After completing your task, simply repeat the wiper stalk action and the wipers will 'park' in the usual position.
    2Zone Climate Control Synchronization
    if you hold down the AUTO button for three seconds, it will synchronize the temperature setting on both sides of the car to match that of the drivers side. When ever the driver changes his temp setting it will also change it on the passenger side, until a passenger changes their side
    2Zone Climate Control Degrees C to Degrees F
    Pressing and holding the Auto and Econ Buttons at the same time will swap the temperature from oC to oF and Visa Versa
    Passenger Door not unlocking
    If you press the unlock button more than twice in quick succession the passenger door ONLY locks itself, unlocks on the fourth, locks on the fifth etc.
    Its a software problem that hasnt been rectified yet but its nothing to worry about
    Coming Home Lights
    The headlights only stay on for the 30seconds or so if you have put just taken the key out of the ignition. If you dont want them to stay on when youve parked up then lock the car, unlock and lock again.
    (Save that oh too familiar "you've left your lights on mate!")
    If you have the lux pack, and the dimming rearview mirrors:
    To turn the dimming feature 'off' feel under the rearview mirror and push the little switch....the LED should extinguish and your mirrors will be clear
    If you use the middle button to open the boot only then never lay your key inside as when you close the boot the car is fully locked with the alarm on.
    press ECON and the UP ARROW button, the one that puts the air near the windscreen vents.
    The left display and panel show the channel + subchannel. The large number is the main channel, with the little number top right being the sub channel.
    The Left twisty bit changes the MAIN channel, the central twisty bit (fan speed) changes the sub channel. I dont think the right twisty bit does anything.
    So far ive only worked out the following :
    MAIN channel 19 has got engine RPM, engine SPEED (km/h). Ive only looked at it for a few minutes but i really wanna work it all out
    A little RCD300 trick
    If you hold down the MENU button whilst on FM or AM, until the radio emits a 'boop' the display will then alter to show a signal meter for the station you are listening to and some other useless bumf.
    does any one know of any more features or furthe advances of those listed?
    Also, various things can be reprogrammed depending on the type of onboard computer or if not by the dealership, e.g. the doors locking at 9mph or having the alarm beep when it is set.
    2 0 0
  2. Re: tips and tricks for golf mk5's
    Jul 2008
    This is a great post. I enjoyed playing about with these tips
  3. Re: tips and tricks for golf mk5's
    Jun 2008
    Quote Originally Posted by golfmk5gttdi View Post
    I would really love to be able to activate both these feature without nipping down to the dealer and paying a small fortune.
    Can it be done?..............anyone?
  4. Re: tips and tricks for golf mk5's
    Jun 2008
    Some really useful info - thanks a lot
  5. Re: tips and tricks for golf mk5's
    Canada
    Quote Originally Posted by stringbeanjean View Post
    Anyone near you on this thread
    https://www.vwaudiforum.co.uk/forum/s...ead.php?t=5319
    They are ready and waiting
    VW Tiguan 4motion 2.0T 2015 - Awesome snow churning 4x4 GTI 😉
  6. Re: tips and tricks for golf mk5's
    Here's one:
    Don't buy new £40ish Aero wiper blades and get £11 replacement rubbers off ebay. It's a piece of **** to slide the old ones out and slide new ones in.
  7. Re: tips and tricks for golf mk5's
    Aug 2008
    excellent post
    thanks very much
  1. tips on GTI
    By master_rud in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-05-2007, 05:12 PM
  2. lambda sensor removal tips
    By achundee in forum Polo - Derby - Lupo - Fox
    Last Post: 03-04-2007, 07:05 PM
  3. GT TDi - any tips to look out for when buying?
    By Welton in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-01-2007, 08:10 PM
  4. removing headlining tips?
    By richbaker78 in forum Passat - Archive Topics
    Last Post: 16-10-2006, 03:38 PM
  5. Audi Tuning tips for AEB 1.8T
    By glen_a4turbo in forum Audi A4 - Archive Topics
    Last Post: 05-08-2006, 07:47 AM
