Thread: Remove interior roof light to change bulb?
  1. Arrow Remove interior roof light to change bulb?
    Dec 2006
    Éire
    Hey,
    Anyone know how to take off the interior light fitting in the roof to change the bulb?
    55 plate a6
    Thanks,
    Paddy
    ___________________________________
    Previously: 03 A4 1.9TDI , 05 A4 2.0TDI S-Line, 05 A6 2.7TDI S-Line Quattro , 06 A4 2.0TDI S-Line Avant, 08 2.0 TDI MK5 GOLF GT SPORT TDI 170 DSG, 10 A6 2.0 LE MANS 170, 19 G30 520d MSport
    Now: waiting
  2. Re: Remove interior roof light to change bulb?
    Mar 2008
    11 Post(s)
    You don't mention which bulb but both are very easy.
    Basically, if its the front set of lights above the driver/passenger then you need to pull off that whole panel.
    Easiest way is
    open the sunglasses holder by pushing it in
    grab the plastic panel and yank it down
    What you will find is it 3 parts will seperate and go everywhere (sometimes two)
    the parts should be the main plastic cover, followed by the centre bit that has the two larger bulbs in and a bit of chrome plastic that decorates it.
    Change the bulb and just clip the panel back in.
    the rear ones above the rear seats is just a flat screw driver job and pry the plastic holder out.
    If the two front bulbs (the brighter ones above the larger plastic bit) has blown, you will need to replace it with a Festoon type bulb (unsure of size)
    If the front set or the rear seat ones have gone, they are a different type.
    I replaced all of mine to be the LED type ones...the Festoon having 24 LEDs on it... VERY bright and white too!
  3. Re: Remove interior roof light to change bulb?
    Aug 2007
    Wicklow
    Anyone know how to take this cover off on the older A6? I've a 2001 and my "Passenger Airbag Off" light intermittently flashes and I want to check for a loose wire.
  4. Re: Remove interior roof light to change bulb?
    Dec 2006
    Éire
    thanks akash .... rep++ !!!
    Now: waiting
  1. How do you change the bulb in the boot/trunk light of a Mk4?
    By torvill84 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-04-2014, 09:00 PM
  2. rear light bulb change
    By arctic blue in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-01-2010, 02:00 AM
  3. VW polo 9N left rear break light bulb change
    By misomiso in forum Polo - Derby - Lupo - Fox
    Last Post: 04-02-2009, 02:35 PM
  4. How to remove the front Turn signal bulb socket to replace bulb
    By rg0115 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2008, 10:47 PM
  5. Removing Instrument Cluster On 2002 Golf V5 To Remove Emissions Warning Light Bulb
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-06-2007, 06:02 PM
