Thread: A4 Brake Size
Results 1 to 10 of 10
  1. A4 Brake Size
    Hey all just wanted to know if any1 knew what size the standard brake discs size on a 2001 2.0 SE (ALT)
  2. Re: A4 Brake Size
    Jun 2008
    Front should be 288x25 right?
    J
  3. Re: A4 Brake Size
    Leicester
    Just responded to your earlier thread again Jim:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=40434
  4. Re: A4 Brake Size
    Apr 2007
    Hampshire
    There are various options of brake sizes fitted to the A4, a 1 size for all policy isnt the case im afraid! If you look at the inside cover of your service book for the sticker that has all the 3 digit codes, one of those codes will relate to the brake option fitted to the car. You could ask a dealer what the VIN details they hold say were fitted but as I wouldnt trust them as far as Fatima Whitbread could throw them i'd just look at your service book sticker!!!
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
  5. Re: A4 Brake Size
    Jun 2008
    That will only show what was on the car and not any changes made by previous owner is car was purchased used.
    The coding on my service book represents "standard brakes" but no mention of size.
    J
    Quote Originally Posted by nickynibbles View Post
  6. Re: A4 Brake Size
    Apr 2007
    Hampshire
    Whats your brake code then, i'll tell you what it means.
  7. Re: A4 Brake Size
    Derby/Tamworth/Bristol
    most accurate way to find out would be to measure them?
    Wheel off. tape measure in hand... go on, get your hands dirty
  8. Re: A4 Brake Size
    Jun 2008
    1LT = Disc brakes, front
    1KP = Disc brakes, rear
    I did have the front wheels off at the shop and measure roughly 320mm thus 312mm but cant for the life of me remember what was stamped on the disc for thickness....25mm or 28mm.
    J
  9. Re: A4 Brake Size
    As far as I can see according to my spreadsheet, Audi dont do a 28mm thick disk on any model. it seems to be either 25mm, 30mm for the heavier cars like the A8 and 34mm for the sports models like the RS6
  10. Re: A4 Brake Size
    Apr 2007
    Hampshire
    Quote Originally Posted by a4_jim View Post
    J
    The fronts are listed as FN3 16" versions, ie 312mm as you have rightly measured. These were the same ones as fitted to my 3.0 qs. Looks like you've got perfectly normal factory fitted brakes there then.
  1. A4 brake disc size
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-07-2008, 06:57 PM
  2. What brake disk size?
    By aaron in forum Golf MK4 - 1999 - 2004
    Last Post: 28-03-2008, 07:42 PM
  3. Front Brake disc size on a 1.6 se
    By mfosbrook in forum Golf MK4 - 1999 - 2004
    Last Post: 27-02-2008, 09:24 PM
  4. TDI 150 Brake Size?
    By trackdaychamp in forum Chat - Anything with wheels
    Last Post: 21-10-2007, 04:27 PM
  5. Golf MK4 GT TDi 115 bhp brake disc size
    By caz1982 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-07-2007, 08:08 PM
