Thread: need to remove turbo to clean vanes
  1. need to remove turbo to clean vanes
    essex
    how do i remove turbo from 1.9tdi avf engine as i need to clean vanes.
    what tools do i need. how hard is it to do?
  2. Re: need to remove turbo to clean vanes
    Sep 2007
    Quote Originally Posted by churp View Post
    I dont think you need to remove the entire turbo to clean the vanes. I used a product by Innotec who supply a cleaning kit for i think £35ish.
    You will probably need to remove the egr valve to get better access and while its off you could clean that too. With this product you will need to remove the outlet side of the exhaust (cat) and spray this liquid bottle in to the tubo and leave it for an hour to dissolve the soot, also you will need to move the actuator arm up and down during the process to free the vanes.
    An hour later you drain the liquid with all the gunk and flush it out with another solution, lastly the 3rd bottle you pour in to the fuel filter.
    Put every thing back together and take it for a test drive.
    I had limp mode and smoke prior to this and this product seems to have sorted this. Ive also had a specialist minimise the use of the egr through vag com.
    Let me know if you need any more info
  3. Re: need to remove turbo to clean vanes
    essex
    what is the name of this product and where can i get it from
  4. Re: need to remove turbo to clean vanes
    Sep 2007
    Heres the link. Also may be worth renewing cat gasket.
    what symptoms are you getting. Why do you think your turbo vanes need cleaning?
    http://www.innotecworld.com/c-1084-turbo-clean-set.aspx
  5. Re: need to remove turbo to clean vanes
    Mar 2007
    Suffolk
    Anyone who has used this -how do you remove the gunk/liquid??
  1. Replies: 0
    Last Post: 29-02-2008, 02:23 PM
  2. turbo vanes.
    By davetdiredi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2008, 07:39 PM
  3. How to clean and keep clean Light Beige Phoenix Cloth interior
    By ackerman821 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2008, 04:36 PM
  4. sticking vanes on my turbo?
    By barney2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-10-2007, 07:21 PM
  5. variable nozzle vanes on tdi turbocahrger
    By glynnd in forum Passat - Archive Topics
    Last Post: 31-05-2006, 01:31 PM
