Thread: Clutch replaced, but still difficulty engaging gears!
  1. Clutch replaced, but still difficulty engaging gears!
    Jun 2008
    South Staffs
    Hi guys,
    Im brand new to the forum, I'm desperately after some advice regarding my VW Polo 1999 1.0l
    Basically, the clutch had been slipping for a while so last week decided to take it to the garage and had it replaced. Now, the problem with acceleration being the same as engine revs/biting point etc... is ok, but the problem of difficulty engaging gears (particularly reverse & 3rd) which has existed about as long as the slipping clutch has not been sorted at all!
    I took the difficulty engaging gears to be a clutch problem also and now i've had the clutch replaced and the problem still exists i'm quite annoyed and worried
    Do you have any ideas what this could be? Gearbox oil change, or some adjustment perhaps im hoping?
    Any help i thank you for in advance.
    Andy
  2. Re: Clutch replaced, but still difficulty engaging gears!
    Quote Originally Posted by ventionandy View Post
    Hi guys,
    Andy
    have you asked the repairing garage if they test-drove the car after fitment of the new clutch and have you asked to see the old parts?
  3. Re: Clutch replaced, but still difficulty engaging gears!
    1835 Post(s)
    The pedal box reaction point of the clutch cable has broken. Remove the lower dash trim and look up at the pedal box (use a small torch) and look for the cable mounting. Then push down the clutch pedal by hand and you will see the mounting is fractured and breaking away from the pedal box. It takes about three hours to replace the pedal box if you have done them before, a lot longer if you haven’t.
  4. Re: Clutch replaced, but still difficulty engaging gears!
    Jun 2008
    South Staffs
    I saw the old worn clutch plates before I took the car away, but did not ask whether they test drove it or not? I'm taking the car back this week anyway because i'm not really satisfied... I have the 12month warranty, so i'll get them to take another look.
    Do you think the difficulty engaging gears is a problem that should have been solved when the clutch was replaced. I don't thrape the car, its only a 1 litre and done only 52k!!
  1. Please Help T4 Clutch/gears
    By redboots in forum The Commercial Range
    Last Post: 11-06-2008, 07:10 PM
  2. Problem with gears/clutch!!
    By katiej in forum Golf MK3 - 1993 - 1999
    Last Post: 31-03-2008, 02:26 PM
  3. GEAR 3 not engaging sometimes.
    By tazz777 in forum Polo - Derby - Lupo - Fox
    Last Post: 30-03-2008, 07:56 PM
  4. Sticky gears, could the clutch air need bleeding?
    By Jeff321 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-07-2007, 10:52 PM
  5. Clutch Faulty - what bits need to be replaced?
    By ChillOut in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2007, 08:33 PM
