Thread: Strange electrical fault ???
  1. Strange electrical fault ???
    Jun 2008
    Hello can anyone shed some light please...
    Mk 3 Golf 1995 TD estate.
    Starting the car after a 6 week period of being stationary I noticed the oil pressure and water temp warning lamps are permanently on. In adititon the mileometer and clock displays have gone out also the speedo is not working.
    I have checked the oil and water senders and they are both fine. If I disconect the leads the warning lamps stay on.
    Engine bay has not been presure washed, car is parked outside.
    Before problem did some work reparing rear wipe loom where it flexes between body and tail gate. Removed and replaced relays when looking for rear wipr fault.
    All were fine before hand.
    Any ideas chaps?
  2. Re: Strange electrical fault ???
    Jun 2008
    possibly where it hasnt been started the internals of the ecu and/or fuse box are damp. try running the car for ages, or given it a blast on the motorway to see if the heat from the engine dries it out.
    otherwise try the option suggested above regarding fuses
    hope this helps
    dave
  1. Strange Electrical Problem???
    By paultuk in forum Golf MK5 - 2004 - 2009
    Last Post: 07-11-2009, 12:11 AM
  2. Strange clocks problem! Electrical fault??
    By Kris214 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-07-2008, 02:51 PM
  3. Audi A4 2.5 TDI (04) Strange ECU fault Please Help!
    By 327521609 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-02-2008, 05:17 PM
  4. Strange Electrical fault
    By S1mon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-02-2008, 10:57 PM
  5. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
