Thread: problems resetting throttle body
Results 1 to 10 of 11
  1. Question problems resetting throttle body
    May 2008
    Hi guys
    Using a mates vag-com 409.1 and cable he got from ebay (that seems to convert the usb to serial) to attempt to reset the throttle body on a 1998 MkIV Golf.
    When I try to do the throttle body allignment, as detailed on the ross-tech site (Using group 098 as 060 doesn't exist), it either says ERROR immediately or comes up ADP RUN for 10 secs then says ERROR.
    I'm getting really frustrated with it so hope someone can help.
    The thoughts I've had on it are
    1) The sample rate is usually about 1.3 - is this too low?
    2) The following DTC comes up every now and again:
    00282 Throttle Position Actuator
    Not sure what it means but I clear it before trying the adaption
    and it still doesn't work.
    3) Do I need to login (11) perhaps?
    Any advice you can give me would be greatly appreciated
    Andy
  2. Re: problems resetting throttle body
    Dec 2007
    Suffolk
    I would try taking the TB off the car and giving it a good clean with carb cleaner to get all the carbon out (Taking care not th scratch it) then put it back together and try agian.
  3. Re: problems resetting throttle body
    May 2008
    Should have probably mentioned, I've cleaned the tb - it was a right mess and was makin the car cut out. Now it revs at 2000-3000.
  4. Re: problems resetting throttle body
    Dec 2007
    Suffolk
    I take it it is the full version of vag com not the shareware 1?
  5. Re: problems resetting throttle body
    May 2008
    Quote Originally Posted by smokey0123 View Post
    yip, full version
  6. Re: problems resetting throttle body
    Bradford
    It could be the TB is actually knackered, and thats why you get the error code and the alighment doesnt work.
  1. throttle body on 1.8 gti
    By peterdenson in forum Chat - Anything with wheels
    Last Post: 22-05-2008, 08:16 PM
  2. Throttle body
    By swerve in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2008, 05:16 PM
  3. throttle body
    By slim1986 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-03-2008, 08:24 PM
  4. Does replacement of throttle body need resetting
    By safo in forum Polo - Derby - Lupo - Fox
    Last Post: 14-01-2008, 08:03 PM
  5. Throttle Body
    By Fibreron in forum Passat - Archive Topics
    Last Post: 26-12-2007, 10:51 PM
