Thread: Leak from one of the switches/sensors where the oil filter sits
  1. Leak from one of the switches/sensors where the oil filter sits
    Hyde, Cheshire
    My parents 96 1.8SE engine code ADZ has developed a leak from one of the switches/sensors that sit atop the oil filter. It is the one nearest the engine block. My question is what do I ask for by way of replacement?
    And while I have your attention what is the other one?
    Dave
    1987 Fiat X1/9
    1993 Golf Mk3 1.8CL - So long and farewell - Sold to Girlfriends Brother
    1994 CBR600
    2002 Peugeot 406 Coupe S&B
  2. Re: Leak from one of the switches/sensors where the oil filter sits
    Sep 2007
    its probably the oil pressure switch.
  3. Re: Leak from one of the switches/sensors where the oil filter sits
    Hyde, Cheshire
    This is actually a picture of mine (AAM) from when it had a similar problem 3 years ago.
    I have indicated the one that has failed on my parents (ADZ).
    The factors offered one that was mentioned as being a direct replacement for the blue one. It is not the blue one that has failed.
    I thought I was well prepared with the info I had. Make, model, & engine code etc.
    Are they both oil pressure switches?
    1987 Fiat X1/9
    1994 CBR600
  4. Re: Leak from one of the switches/sensors where the oil filter sits
    May 2008
    my best advice is to remove leaking switch and read the code and pressure
    rating on top, i've had problems with both facters and vw parts over these switches before. with both insisting they were giving correct switch, it is best to be armed with this info as will save you multiple trips to your parts
    store were those guys will try to convince you your wrong and their right.
    the wrong switch will give you a headache
  5. Re: Leak from one of the switches/sensors where the oil filter sits
    Hyde, Cheshire
    Cheers Buzby
    The failed one was/is 056919081E 1.6-2.0 Bar
    The blue one is 028919081D 0.15-0.35 Bar
    Dave
    1987 Fiat X1/9
    1994 CBR600
  6. Re: Leak from one of the switches/sensors where the oil filter sits
    May 2008
    hope i was of some help Dave,
    safe driving
    take care Connor
  1. Fuel Filter Leak Problem
    By Andy The Bubble in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 12:52 PM
  2. Pollen filter water leak
    By cuffbert in forum Golf MK3 - 1993 - 1999
    Last Post: 15-01-2008, 08:30 PM
  3. Fuel filter leak...
    By sherlockuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-08-2007, 09:09 PM
  4. Air filter sensors
    By Niklock in forum Archive posts
    Last Post: 01-06-2007, 06:20 PM
  5. Pollen Filter leak - Easy fix....
    By SammyP in forum Passat - Archive Topics
    Last Post: 13-03-2007, 06:12 PM
