Thread: dual climate control temperature on passenger side no changing.
  1. dual climate control temperature on passenger side no changing.
    May 2008
    Hi All,
    I have a 2002 a4 tdi 130bhp. On my dual climate control panel the passengers temperature never changes despite altering the climate control panel temperature which does work by the way. The passenger side is always blowing at the same temperature, drivers side is however is working fine. Anyone have any ideas. Did speak with a mechanic who said the whole dash will have to come out. Is this true? Already not liking the sound of the bill!
  2. Re: dual climate control temperature on passenger side no changing.
    Angus, Scotland
    Hi there,
    If you change the passenger side then it will work independantly of the drivers side. To re-sync them to each other hold down the Auto button on the drivers side and the passengers sdie will change to it and will continue to change until the passenger changes the temperature.
    Works the other way round too!!
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  3. Re: dual climate control temperature on passenger side no changing.
    May 2008
    Hi thanks for your reply but i think you misunderstood what is i was mentioning. I dont have an issue with the climate control panel temperature display just that the temperature (actual temperature) of the passenger side is always cold even if the climate control panel says HI temp.
  4. Re: dual climate control temperature on passenger side no changing.
    Angus, Scotland
    Oh!! My bad!
    Hmm.... that doesn't sound right, could be the temperature sensor is damaged/faulty. Not sure if Vag-Com would pick that up but would be worth trying to get a scan done. Not sure off hand where they are mounted but think they are behind a vented panel either at the controls or in the roof lining. Think the controls are more likely, will try and have a look tonight if no-one else throws up some info.
    Where abouts are you located? Might be someone near by with Vag-Com that can have a look for you!!
    Paul
  1. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  2. Is there a way to syncronise the dual climate control?
    By Niall76 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2007, 03:17 AM
  3. changing climate control
    By Dozz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2007, 11:49 AM
  4. changing wiring looms for climate control
    By allnjms in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-02-2007, 06:28 PM
  5. Rear passenger climate control
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-01-2007, 04:11 PM
