Thread: Anyone explain "stage 1" and "stage 2" torque settings?
  1. Anyone explain "stage 1" and "stage 2" torque settings?
    Mar 2007
    Nearing the end of my suspension arm change, just need to torque everything up. In the workshop manual it states "stage 1" and "stage 2" torque settings. Not quite sure what this means.
  2. Re: Anyone explain "stage 1" and "stage 2" torque settings?
    7 Post(s)
    Quite simply;
    Stage one, tighten everything to x/nm of torque.
    Stage two, tighten everything to x/nm of torque OR a further x degrees.
    I don't know what the spec's are on what you need to tighten but I'd assume the stage one would be a figure in nm (newton metres of foot pounds) you would use a torque wrench on and stage two would be an angle by which you would have to further tighten everything.
    Also note that on suspension components you normally need to do the final tightening with the component loaded i.e. the weight of the car on the ground on its wheels.
  3. Re: Anyone explain "stage 1" and "stage 2" torque settings?
    Mar 2007
    Thanks for that. I thought stage 1 was off the ground and stage 2 was on.I'm changing my suspension arms and just got to torque things up.Your right, it says for one stage 1 50NM, and stage 2 90 degrees.I think I will loosen everything up before I lower it down, then torque it all up. Might have to do it on some ramps though, if i cant get to some of them. Thanks for your help.
  4. Re: Anyone explain "stage 1" and "stage 2" torque settings?
    May 2008
    I don't know, but would imagine Stage 2 should be done with the weight of the vehicle on the suspension. In that case, ramps are going to make it a lot easier....
    2001 B5 Passat Estate 130TDI Sport, Audi S2 Coupe, Audi 80 Sport Edition.
  5. Re: Anyone explain "stage 1" and "stage 2" torque settings?
    Jul 2008
    The front of the car is supported on axlestands, of course?!
    Make sure the suspension bolts are loose, then place a jack under the bottom balljoint. raise the hub until the car nearly starts to lift off the nearest stand, then let it down a touch. You can now torque the bolts a bit easier than with the car resting on the ground, if you don`t have ramps.
    Nik.
  1. Multitronic - help me "explain" to the dealer without Basil Fawlty tactics
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-04-2008, 12:21 AM
