Thread: engine rattle
  1. engine rattle
    hi wonder if anyone can get there heads around this one
    i have a mk4 golf 1.4se 2001 95k and the engine makes a rattling/tapping noise i have had this looked at on many occasions by various mechanics
    the first guy said it was the tappets and would require a new set of hydraulic tappets £800
    2nd guy said waterpump was rattlin i have had this changed still not solved it
    vw mechanic says its piston slap and requires a new engine
    has anyone else had this with a mk4 golf as i need to sort it but am unsure what to do
    would appreciate any help thanks
  2. Re: engine rattle
    Feb 2007
    Nottingham
    Does it rattle at any particular times ie when cold? warm? in a certain gear or rev range or is it more constant? Doe the engine still perform properly and is the car fully serviced?
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  3. Re: engine rattle
    it does it when idling, cold or warm has been regularly serviced
    the only time it goes away is when going over 50mph
  4. Re: engine rattle
    Dec 2007
    Belfast
    Hey Starskee,
    I am having much the same problem with my 1.6 16v petrol 2001 50,000mls.
    A VW tech I know suggestd to me that it may be down to the fuel I am using, not sure why though.
    Sorry I cant be of any more help !!
    Mark.
  1. TT 1.8t 225, engine rattle?
    By lucky225 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 15-05-2008, 09:26 PM
  2. quattro coupe 1989 2.2 engine rattle
    By smudger41 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 28-02-2008, 08:19 AM
  3. s3 rattle on engine
    By rogs in forum Audi A3 - Archive Topics
    Last Post: 05-02-2008, 10:05 PM
  4. 1.8 20v top end rattle
    By siavant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-09-2007, 10:39 PM
  5. Top End Engine Rattle
    By GSD in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2007, 09:44 AM
