Thread: Boot / trunk lock activates but won't unlock Video
  1. Boot / trunk lock activates but won't unlock Video
    London
    I just replaced the boot / trunk LOCK in my 1999 1.8T VW Passat. The spring inside the old lock, which flicks a lever over when the boot /trunk is in the closed position, had broken. The new mechanism now locks fine but will not unlock.
    However, my new problem is that the electric mechanism will not unlock. I am also unable to open the lock manually using the key. From inside the car I can reach behind the rear seats, pull the unlocking bar then it unlocks.
    I cannot see why the unlocking rod is not moving. Just looking at the piston moving and the bits that are connected to it, I cannot see that the angles and connections would ever result in the rod moving but there seems only one way of connecting the unlocking rod to the lock so I am stumped.
    Here's the video:
    http://uk.youtube.com/user/headachefiftysix
  2. Re: Boot / trunk lock activates but won't unlock Video
    London
    Er fixed it - tail between my legs.
    The unlocking rod does not actually move because the boot is not intended to flick open itself.
    Instead, it seems, the piston retracts to allow the rod to be moved when one opens (as opposed to unlocks) the boot from the outside. Anyway it all works fine now. I am learning (graudually).
  3. Re: Boot / trunk lock activates but won't unlock Video
    Sep 2008
    Quote Originally Posted by headache56 View Post
    Here's the video:
    awsome, every one should use utube link.. Ta
  1. How do you change the bulb in the boot/trunk light of a Mk4?
    By torvill84 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-04-2014, 09:00 PM
  2. Please Help Passenger door lock/unlock
    By doug.howsie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-05-2008, 02:56 PM
  3. Headlights come on when I lock/unlock my car?
    By rick_s in forum VCDS - General Questions
    Last Post: 02-03-2008, 12:22 AM
  4. Headlights turn on when I lock/unlock my car...
    By rick_s in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-02-2008, 01:53 PM
  5. Power to the boot / trunk
    By Audichap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-09-2007, 02:56 PM
