Thread: Swimming pool Audi A4!
Results 1 to 10 of 14
  1. Angry Swimming pool Audi A4!
    Maidenhead, Berkshire
    Hi, just got into my 1996 Audi A4 Avant to find 2" of rain water on the passenger side floor pan (front and rear). I've had the car for about 6 months and this is the first sign of any leak. Does anyone know if this is a known problem with these cars? and if so, where do I look to find the leak? Any help would be much appreciated.
    Rob
  2. Re: Swimming pool Audi A4!
    1837 Post(s)
    Do a search; it is a huge problem and the subject of a recall at Audi. It is due to the plenum chamber drains under the battery and servo becoming blocked. The plenum chamber fills up and the water pours in through the heater intake. It causes central locking problems on later cars with the control unit under the passengers carpet (not yours) but more alarmingly it also causes the servo to fill with water and corrode the internals which can lead to the nearside front brake sticking on and even total brake failure if it is cold enough for the water in the servo to freeze solid.
  3. Re: Swimming pool Audi A4!
    Wow, could end up being really serious then, thanks alot for your help, I'll get straight to work on it.
    Regards
    Rob
  4. Re: Swimming pool Audi A4!
    kent
    well heavy rain today, i moved the car this afternoon and could hear water "sloshing" from below the windscreen area,
    dunno where it went tho ????
    Stu
  5. Re: Swimming pool Audi A4!
    1837 Post(s)
    Clear the drain tubes and that means removing the battery.
  6. Re: Swimming pool Audi A4!
    kent
    cheers, i'l have a lil looky when it stops raining :lol:
    prob not til the weekend now!!!!!!!!!!!!
    Stu
  7. Re: Swimming pool Audi A4!
    May 2008
    Finland
    And while you're at it, remove the rubber grommets around the water drainage holes.
    I recently had my B6 serviced and the dealer performed campaign maintenance on it at the same time. The campaign is 51B7 and it concerns all the B6 bodied A4s and involved removing the rubber grommets from the drainage holes.
    ____________________________________________
    VW Golf Mk.V 2.0tdi 4Motion
    VW Golf Mk.IV 1.4i
  8. Re: Swimming pool Audi A4!
    1837 Post(s)
    Not removing them permanently I hope, they are there for a reason. The Campaign only stipulates to poke them through.
  9. Re: Swimming pool Audi A4!
    May 2008
    Finland
    I'm not sure if they removed them completely or just enlarged them, but it's still a campaign fix.
    At least on the B5 they didn't seem to do anything else than protect the edges of the drainage hole.
    VW Golf Mk.IV 1.4i
  10. Re: Swimming pool Audi A4!
    1837 Post(s)
    They are tubes with flap valves at the bottom. Their purpose is to prevent fumes from under the car being drawn into the heating system.
  1. The Auto Pool Audi in Iver
    By A6_JAck in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-04-2008, 01:32 PM
  2. swimming pool as standerd???
    By alpinehead in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-03-2008, 11:54 AM
  3. A3 - Swimming Pool
    By diggy in forum Audi A3 - Archive Topics
    Last Post: 25-01-2008, 02:18 PM
  4. MkIV Golf swimming pool
    By bgvw in forum Golf MK4 - 1999 - 2004
    Last Post: 14-02-2007, 06:57 PM
  5. Our Sharan is a swimming pool........
    By ziggi in forum Touran - Sharan - Caravelle
    Last Post: 05-09-2006, 09:05 PM
