Thread: Turbo whistling noise???
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Turbo whistling noise???
    #11
    Pembrokeshire
    22 Post(s)
    well, could be the turbo on its way out, or a split boost pipe or cracked intercooler, leaking egr valve, but basically its likely to be a leak somewhere in the high pressure boost side of the inlet side of things, but could also be a leak in the exhaust manifold.
  2. Re: Turbo whistling noise???
    #12
    Nov 2016
    GB
    Turbo has been rebuilt and well maintained engine has bew intercooler new egr valve it oly started today to make that noice but when stationery and i rev it it doesn't do it oy wen drive but its definitely coming from engine not from wind
    Sent from my SM-G920F using Tapatalk
  1. Whistling Noise
    By bleasy in forum Golf MK4 - 1999 - 2004
    Last Post: 04-04-2009, 07:32 AM
  2. Whistling noise from n/s rear when changing gear.. Common noise in all PASSATS ??
    By Gaz_2005_Passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-12-2008, 06:46 PM
  3. whistling noise
    By phoenix510 in forum Passat - Archive Topics
    Last Post: 10-02-2008, 10:40 PM
  4. Whistling Turbo
    By alecmac in forum Vento - 1994 - 1998
    Last Post: 15-03-2007, 12:31 AM
  5. Brakes making whistling noise
    By thecoolalhambra in forum Passat - Archive Topics
    Last Post: 18-09-2006, 03:11 PM
