Thread: Faulty electic mirrors golf mk4
  1. Angry Faulty electic mirrors golf mk4
    May 2008
    Hi there - am going mad trying to repair electric mirrors on mk4 golf. Both mirrors just stopped working one day - nothing - and then the switch fell apart. have replaced the switch but still nothing on either side. Does not appear to be any current running to the switch - does not light up with instruments etc - no apparent voltage of any sort to any of the 4 wires feeding the plug. Does the switch run off one of the relays under the dash? fuses 1 & 5 seem fine as are the rest of the fuses. The wires running between the door and body are all in good order no obvious brakes etc. This is driving me mad - has anyone ever had a similar problem? the mirrors are the non heated version.
  2. Re: Faulty electic mirrors golf mk4
    eurocrat Guest
    No, not quite the same, but recently the (heated) electric mirros on my 2000 GTi started behaving wierdly - if you select the left mirror then the joystick moves both mirrors together (in, out, rotate up, rotate down).
    If you select the right mirror then only this mirror is controlled.
    Strange, although in fact quite useful!
    Btw, I think the heating function doesn't work anymore, but must wait for winter to test ...
  3. Re: Faulty electic mirrors golf mk4
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by eurocrat View Post
    Standard feature on VAG cars from around 2000. does this on my passat also.
    Nothing to see here, move along..
  4. Re: Faulty electic mirrors golf mk4
    Apr 2007
    N.Ireland
    I believe this is the normal way that the mirrors operate
    Golf GTD 2.0 DSG (ACC | Winter Pack | 18" Vancouvers | RCD510 | Parking Sensors, Rear Camera & Park Assist | Cruise Control | Flat Tyre Indicator | Luxury Pack | Rear Airbags)
  5. Re: Faulty electic mirrors golf mk4
    Aug 2008
    Quote Originally Posted by rfpewan View Post
    The remote mirrors operate from the window can module. Will need some equipment to clear any fault codes from the control module and then test further.
    I hope this will help
  6. Re: Faulty electic mirrors golf mk4
    Southampton, UK.
    Yes, it's standard, although mine were the other way round, as in on the three Mk4 Golf's I've had, moving the right one (off side) moves the near side one too. Selecting the near side one only moves the mirror on that side.
    2003 VW Golf Est 1.9 TDI 130
    2006 Audi A3 2.0 TDI Sport 140
  1. GOLF N REG Electic window problems
    By Mikege in forum Golf MK4 - 1999 - 2004
    Last Post: 22-05-2008, 08:11 PM
  2. Golf GTI Folding Mirrors
    By steadiheli in forum Golf MK5 - 2004 - 2009
    Last Post: 29-02-2008, 07:04 PM
  3. vw golf mk4 central locking faulty
    By scotland007 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-08-2007, 10:33 PM
  4. Golf TDI MK4 Faulty Gears
    By 2Dcadman in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2007, 12:02 PM
  5. HELP! - faulty brake/indicator lights, golf gt tdi, 1998
    By gtisamantha in forum Archive posts
    Last Post: 24-07-2006, 02:45 PM
