Thread: A4 TDI Starting Problem~1996 110 Auto
Results 1 to 8 of 8
  1. A4 TDI Starting Problem~1996 110 Auto
    Mar 2008
    A good freind of mine has developt a strange fault,Where as after starting engine cuts out... Re start then does same again,one or two more tries then it starts and is ok till the next morning.
    my self i am thinking glow plugs or a sensor of some type,I should also mention he is running on bio,Any help welcome Thanks scott
  2. Re: A4 TDI Starting Problem~1996 110 Auto
    Mar 2008
    Don't laugh at this. The fault is most likely the key (More to the point the RFID chip in it) Mine did the same thing and I was thinking all sorts of horror stories but read to try the spare key and what do you know. Starts first time every time.
  3. Re: A4 TDI Starting Problem~1996 110 Auto
    Mar 2008
    Thanks for that mate,Just had plugs out and one was down... did you have a key type symble on your dash board,This has only just started to apear,Is it an audi job for new key...Lost the spare lol.
  4. Re: A4 TDI Starting Problem~1996 110 Auto
    Mar 2008
    No the key symbol didn't come on. The car fired revved once and cut out. After about 3 or 4 goes it started and worked.
    I actually am still using the spare key so I presume a new key or a recode of the faulty key would cure the problem.
    weirdest thing I have ever come across.
  5. Re: A4 TDI Starting Problem~1996 110 Auto
    Mar 2008
    Guess what??? the plugs havent cured the problem.. is yours still running ok?? thanks
  6. Re: A4 TDI Starting Problem~1996 110 Auto
    Mar 2008
    yes it is fine with the spare key. If I use the original key it does the fault again.
  7. Re: A4 TDI Starting Problem~1996 110 Auto
    Quote Originally Posted by avantscott View Post
    Key on dashboard = Oil Problem IIRC
  8. Thumbs up Re: A4 TDI Starting Problem~1996 110 Auto
    Mar 2008
    What sort of oil problem???
    It has a seperate oil service light,Do you meen oil pressure??
  1. Starting problem on 1800 petrol 1996 Passat estate
    By edmunds in forum Early Passat Forum - Pre 97
    Last Post: 14-05-2008, 09:01 AM
  2. A6 2.6 V6 auto estate starting problem
    By Stevethesax in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-05-2008, 05:05 PM
  3. Starting problem on 1800 petrol 1996 Passat estate
    Last Post: 01-03-2008, 01:42 PM
  4. 1996 Passat 1.9TDI Starting Problem
    By Wallace Passat in forum Early Passat Forum - Pre 97
    Last Post: 06-02-2008, 04:37 PM
  5. VW Sharan SE Auto intermittent starting problem
    By Broley in forum Touran - Sharan - Caravelle
    Last Post: 19-02-2007, 12:51 AM
