Thread: VW Polo 2003 rear doors wont lock
  1. VW Polo 2003 rear doors wont lock
    Sheffield UK
    The Rear Doors On My Wifes Polo Tdi 2003 5 Door Will No Longer Lock With The Remote, And Now Have To Be Locked Manually. They Also Will Not Unlock With The Remote Either But The Front Doors Work Fine.
    Any Suggestions Welcome
  2. Re: VW Polo 2003 rear doors wont lock
    probably a failed vacuum pump. might just be a pipe has become disconnected. no idea how to pull modern polos apart so thats as much help as i can give!
  3. Re: VW Polo 2003 rear doors wont lock
    Sheffield UK
    Thanks for that g40jon.
    Now sorted thanks to vagcom, plugged it in and checked the locking system code 46 the code was set for a two door model, added a digit and hey presto it worked.
    Better still, it still works "a week later" heaven knows what happened to change the code in the first place!!!!
    If any one needs a vagcom scan, in and around worksop/sheffield area, I can do one for you for a pint or two.
    No promises on a quick fix though, as I only received it last week and still finding my way around it.
  1. Rear Doors On Passat Locked !!!!!!help
    By MR_SAT in forum Early Passat Forum - Pre 97
    Last Post: 15-07-2008, 09:09 PM
  2. Rear doors wont open from inside
    By dean-nez in forum Golf MK4 - 1999 - 2004
    Last Post: 25-04-2008, 10:43 PM
  3. Doors auto lock
    By huorsa in forum Audi A3 - Archive Topics
    Last Post: 24-01-2008, 12:21 AM
  4. Remove rear light cluster - Polo 2003 (03) 1.4S 5DR
    By jon_iz in forum Polo - Derby - Lupo - Fox
    Last Post: 14-01-2008, 12:47 PM
  5. All Doors Wont Unlock
    By elmoreno1785 in forum Passat - Archive Topics
    Last Post: 05-05-2007, 11:06 AM
