Thread: bora engine management system light on, car running fine!!!!???
  1. bora engine management system light on, car running fine!!!!???
    May 2008
    I have a 51 vw bora, it is due a service in 1400 miles. The engine management system light has come on, the car is running fine with no problem, i usually put normal unleaded in the car but this tank i used shell v power, the car blew some black stuff for a day or so but is now running fine, but the light is still on, any suggestions??
  2. Re: bora engine management system light on, car running fine!!!!???
    London
    The engine management light covers many issues within the engine. Some of them critical enough, but some are trivial.
    Bottom line is that without a fault read you will not know whether the engine is in danger, or if you can safely continue driving through to your next service.
    I had the same fault, and it ended up being a faulty rear brake light relay (the lights were working fine though...). I am glad I took it to the garage despite it costing an extra few £££, as it may have been something much more severe.
    If you can get a fault reading at home - it may (but not necessarily) give you the answer.
  1. Engine management light on in Bora 1.6 SE
    By andie99uk in forum Bora - 1998 - 2005
    Last Post: 12-10-2007, 03:17 AM
  2. VAG-Com owners willing to help with engine management light on vw bora
    By dustman in forum Chat - Anything with wheels
    Last Post: 31-08-2007, 06:09 PM
  3. hi forum members, bora engine management light problem.
    By dustman in forum New Member Introductions
    Last Post: 31-08-2007, 09:16 AM
  4. VW Golf 2002 EPC Light on ( Engine Management System )
    By padrag_king in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-07-2007, 11:33 PM
  5. Engine management System Warning light
    By petergregg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-01-2007, 03:46 AM
