Thread: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
Results 1 to 10 of 18
  1. Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    This is my 1st post and hope somebody can help.
    I have an A4 2.8Q 1998 and the brake bulb failure indicator on the dash indicates a bulb failure. I have replaced both bulbs with Osram and other brands, but the indicator stays illuminated even though the bulbs work ok.
    Does anybody know what the problem is?
    Many thanks,
  2. Re: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    May 2008
    Are these original Audi bulbs? Any others may not work well or will work for only a short time before going bad.
  3. Re: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    Yes, tried everything incl. original Audi bulbs. . warning light still on!
  4. Re: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    Southern County Softy
    20 Post(s)
    Try cleaning every bulb holder on both sides of the car.
    A4 2.5 tdi QS (mapped)
  5. Re: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    Jul 2008
    Quote Originally Posted by IrlA4 View Post
    Many thanks,
    Check to ensure that you have the correct bulb in the correct position, remember there are fog lights and if you have had the bulbs you may have them mixed up?
  6. Re: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    thanks guys, tried all of the above, but no luck yet :-(
  7. Re: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    If you are sure you have the right bulbs in the right place,try removing one of the battery terminals for 30 secs.
  8. Re: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    I'm having the exact same problem with my 98 S4, Tried replacing both rear bulbs and checked all the contacts but still no joy i've seen a few other posts on the net but still no answers! if you have any joy let me know!
  9. Re: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    probably worth adding that i had it checked out by a mate on his vagcom laptop n it came up with no fault code
  10. Re: Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    Barnsley
    Have you checked the high level brake light? Its most likely a fault with the lights, a burnt out bulb or additional light fitted, the light detection system works by knowing what power the lights should normaly use, if too much power is being used, ie extra brake light, or too little, blown or incorrect bulb, the system thinks a light is out, using LED bulbs can put the light on too, as can incorrectly fitted towbar wiring, a special relay has to be used on vehicles with light failure detection systems, an intermittent fault also has the effect, have someone press the brake pedal and tap the lights to see if the light goes off and on, could be a loose connection or faulty bulb.
  1. 3rd brake light bulbs - replaceable?
    By a4tdidriver in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2008, 07:44 PM
  2. a4 brake light bulb
    By mike d in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-02-2008, 07:00 PM
  3. 3rd Brake Light Bulbs
    By audinut in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-01-2008, 10:33 PM
  4. RS6 Brake Light Bulb Replacement
    By rief944t in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-07-2007, 08:37 AM
  5. brake light bulb!!!!
    By jjt5 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2007, 11:09 PM
