I have just purchased a VW Sharan 1997 Has anyone had problems with electric windows? The drivers window will work ok until you start the engine then it will only go up and will not go down . It is fine on pre-ignition with the engine off, Also the passenger front works ok from its own switch buth not from the drivers switch, Any help / ideas etc more than welcomed,
Cheers GARY
