Thread: hi idiling speed, hi revs
  1. hi idiling speed, hi revs
    hi friends
    got a skoda felicia 1.3 gli mpi skoda engine. it used to have a miss when cold n would not start if it failed the first time had to be pushed. it seems as if it over flowed . now what i did was to remove the top black cover n cleaned the carbon build up over the butterfly . after trying to start the revs went very hi up to 1100 revs and as i drove they would stick up to 2500 revs until i hit on to the acc pedal then would drop down to 1200revs still very hi.
    checked all vacuum pipes all ok i dont know what has gone wrong .
    i am in kenya and this is the only skoda in the whole country pl need help to keep my car going.
  2. Re: hi idiling speed, hi revs
    Jun 2008
    It's quite common for the inlet manifold gasket to fail on these, giving the symptoms you describe.
  1. Audi A4 smoking and unusual idiling
    By Yorkshireman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-04-2008, 09:28 PM
  2. Replies: 2
    Last Post: 26-03-2008, 07:46 AM
  3. Can you replace 4-speed gearbox with 5-speed? Golf ryder 1.4
    By Finjamin in forum Golf MK3 - 1993 - 1999
    Last Post: 14-01-2008, 11:31 PM
  4. Kangaroo-ing at low revs and Revs staying high on Gearchange.
    By Dancake in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 05:50 PM
  5. revs and idel speed problems
    By Hawk in forum Audi A3 - Archive Topics
    Last Post: 29-01-2007, 02:38 PM
