Thread: understanding Vag com fault findings
  1. Question understanding Vag com fault findings
    Jul 2007
    Hi I'm completely new to vag com and bought 2 leads one usb and one SKPANG_lead version two.
    I can get usb to connect no probs but errors on 08-Auto-HVAC saying communication error.
    The SK lead does not connect at all. (Can any one advise on this?)
    I have managed an engine fault search and details below. The problem is the seems to lack turbo, no power uphills other than than runs smoothly.
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01: Engine
    Controller: 038 906 012 AF
    Component: 1,9l R4 EDC 0000SG 2825
    Coding: 00002
    Shop #: WSC 06325
    2 Faults Found:
    17957 - Boost Pressure Regulation Valve (N75): Open or Short to Ground
    P1549 - 35-10 - - - Intermittent
    17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
    P1144 - 35-00 - -
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 8E0 614 111 AB
    Component: ABS 5.3 FRONT D00
    Coding: 0273004281
    Shop #: BB 24548
    No fault code found.
    Address 08: Auto HVAC
    Controller: 8D0 820 043 M
    Note: Excessive Comm Errors
    Control Module Part Number: 4B0 035 186 E
    Component and/or Version: Radio 0001
    Software Coding: 00201
    Work Shop Code: WSC 06325
    1 Fault Found:
    00849 - S-contact at Ignition/Starter Switch (D)
    36-10 - Open Circuit - Intermittent
    Also on the dash there is an orange light (0) can anyone advise what the fault is.
    Any help on the matter is greatly appreciated.
    Thanks in advance
    Grover
  2. Re: understanding Vag com fault findings
    Angus, Scotland
    Well, the lack of power uphills combined with the MAF sensor fault would lead me to suggest the MAF sensor itself.
    I have had this fail on my 1.9TDi Golf in the past and the symptoms were identical!!
    As for the orange symbol, any kind of description would be good!!
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  3. Re: understanding Vag com fault findings
    Jul 2007
    Sorry for not making it clear the orange symbol is this :
    (0)
    It is in orange and on all the time not flashing.
    Thanks in advance
    Grover
  4. Re: understanding Vag com fault findings
    Angus, Scotland
    I'm just guessing but I think that is a brakepad wear warning light.
    Does it not say in your manual??
    Paul
  5. Re: understanding Vag com fault findings
    Jul 2007
    Unfortunately don't have a manual at hand.
    Just read on another website that it is a brake pads worn light.
    Is there any telling which side the fault is?
    Thanks in advance
    Grover
  6. Re: understanding Vag com fault findings
    Angus, Scotland
    No, but if you are replacing the pads you should replace both sides!!!
    You should be able to see by looking through your wheels whether it's the front or back. I assume that the back pads have the sensor also!
    Paul
  1. Diesel Treatment Findings
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-02-2011, 08:18 PM
  2. abs fault!!!?????
    By drew smith in forum Audi A3 - Archive Topics
    Last Post: 13-02-2008, 04:40 PM
  3. Air con fault - help!!
    By LeeinBunwell in forum New Member Introductions
    Last Post: 13-10-2007, 07:59 PM
  4. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
  5. ABS Fault
    By mygolfvr6 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-07-2006, 07:37 PM
