Thread: Allroad hints for reliability
  1. Allroad hints for reliability
    My local Audi servicing manager gave me the following advice to keep costs/problems away. Hint 1 - When you change the cam belt also replce the water pump (about £60) as it run on the cam belt and if the Wpump fails (which they do) it usually causes the cam belt to jump and wreck the engine. Hint 2 - most suspension failures are on cars that rarely/never use the offroad susp setting as the susp seems to dry out and fail if not used to its full range of movement - a bit like yoga keeping your joints in fine condition!
  2. Re: Allroad hints for reliability
    Aug 2008
    saundersfoot
    Has anyone or can you upgrade the shocks on the allroads?, also I read about upgraing the anti roll bars, carn't remeber the make but it was highly recomended.
    I know it's straying from original thread but I couldn't see how to start a new one
  3. Re: Allroad hints for reliability
    Feb 2007
    Quote Originally Posted by crashburnfly View Post
    I couldn't agree more crashburnfly.Seems a no brainer to change the water pump especially as cambelt changes are every 80k.That's quite a long interval.
    Have you had any problems with Allroads???
    djl
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  4. Re: Allroad hints for reliability
    Mar 2008
    Hulst, The Netherlands
    Hi, I own a 2001 allroad and take very well care of the car. After 150000 km the compressor broke and now the car drops wenn left on level 2 within 3 hours all the way down The comprssor costs 1000 euro to replace.
    Don't get me wrong I love my allroad it drives like no other car but...
    tyhe sus[entions is troublesome. Keep the airstuds clean! Leaks do not come from the rubber airbags but from the metal stud it moves in. So remove dirt sheak for leaks (water and soap spray) and if there is al leak solve it otherwise your comprssor will die
    kind regards Bas (Hulst, The Netherlands)
  5. Re: Allroad hints for reliability
    Nov 2008
    Also consider the idler pulley on the 2.5TDI engine. Mine disintegrated at 180,000miles. So i think this needs to be changed at evey 2nd cam belt swap. Luckily the cbelt did not snap!
    When I got rid of the car it had done 248,000 miles, and had a set of cams at 180,000 as well as the idler pully. I never ever put in any oil between services. Having read a few posts on the subject of cam wear I wonder if Audi ever bothered to cure the problem?
  1. Hints & Tips to improve Performance - Audi A6 2.4 Auto 1998 Model
    By evil_skint in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-04-2008, 11:21 PM
  2. MK1 TT - reliability
    By the.dude in forum TT - 8N Forum - 1998 - 2006
    Last Post: 17-01-2008, 02:41 PM
  3. Fox Reliability
    By alanb9013 in forum Polo - Derby - Lupo - Fox
    Last Post: 17-12-2007, 10:54 AM
  4. Cant get Boot trim offmy A4 avante 96? any hints
    By MattA4Tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-09-2007, 07:11 PM
  5. R Reg Passat - Hints on ABS Control Unit
    By grahamnutt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-07-2007, 07:17 PM
