Thread: Possible to disable immobilizer
Results 11 to 20 of 32
  1. Re: Possible to disable immobilizer
    Canada
    The answer is YES you can disable the Immobilizer within the ECM with rewriting the bin file.
  2. Re: Possible to disable immobilizer
    Quote Originally Posted by Issac Hunt View Post
    01176 - Key Faulty: Signal too Low
    Possible Causes
    • Low voltage in key-battery
    • Bad connections between immo reader coil and immo control module
    Possible Solutions
    • Replace key-battery
    • If more than one key acts like this, check / clean the connector between immo reader coil and immo control module, the contacts tend to oxidize
    • There is also another known issue with the wiring between reader coil and immo module, they are known to be too short so there is a 'longer' wiring (8D0-972-275) available
    I quote this from Ross-Tech Wikki, but I am puzzled as to how a low remote fob battery can affect the immobilizer?
  3. Re: Possible to disable immobilizer
    Canada
    The members at Ross-Tech Wiki, could have "misquoted" another piece of information. Members that have access, can edit that mistake. We all know that the battery within the remote, is strictly for Central locking (address 35) or Comfort control (address 46).
    The issue with the reader coil is valid, the wires have disconnected or had higher than normal resistance causing this fault within the Immobilizer. The first test is checking the coil. Testing the key(s) is the next test reading block 022 at the Instrument cluster (address17) There, you'll see if the key(s) is authorized, ECM response, Key(s) response and adapted keys.
    If the Immobilizer is suspect, disabling the Immobilizer within the ECM is a good test. That doesn't mean that the instrument cluster isn't suspect either. Unfortunately, that procedure can't be accomplished with the cluster.
    "God didn't play dice with the universe" Einstein
    "there are no answers, it's the choices that are made" AF
    Don't PM me for help, I don't answer them! If you're unable to post the details like year, make, model with a scan, I can't help you.
  4. Re: Possible to disable immobilizer
    Canada
    Adding to the battery. If the vehicle battery is low and if the vehicle key was ON and the key was NOT recognized because of a low voltage issue, expect that fault. Another problem is when stater current draw is higher then specifications. That fault would be produced because of the same situation, low battery voltage. Low system voltage is not tolerated in the CAN and Immobilizer system. The worst mistake by vehicle owners and repair facilities is to "boost" or "jump" start the vehicle. High current and voltage spikes are again not tolerated and expect controller damage if continued. The simple way out of that situation is a "booster pack" attached to the system battery for 20 to 30 minutes the "equalize" system voltage. The best way is to replace the vehicle battery but still having the "booster pack" attached to the electrical system. That way, none of the customers "adaptations" are lost and vehicle programming is minimized.
  5. Re: Possible to disable immobilizer
    Aug 2008
    Quote Originally Posted by Eshrules-Enterprises View Post
    I had one of my customers asking this very same question last week. If you could disable the immo at any given time, it wouldn't be much of an immobiliser TBH...
    you're better off addressing the issue rather than trying to simply de-activate it.
    another thing to bear in mind, is the impact this may have on your insurance, many companies consider their insurance void if a vehicle is fitted with an immobiliser which fails to function
    it is possible... and takes roughly 1 - 30 mins - only works pre 2001 though
  6. Question Re: Possible to disable immobilizer
    Dec 2008
    Quote Originally Posted by ecmbuster View Post
    OK, so I'm guilty. I have replaced the battery on my 1995 A4, and now the immo light is flashing and won't let me start the car. Any suggestions would be gratefully recieved.
  7. Re: Possible to disable immobilizer
    #17
    Oct 2009
    Mauritius
    Quote Originally Posted by greeny122229 View Post
    Can i know how the immo on av Vento 1997 can be disabled.
  8. Re: Possible to disable immobilizer
    #18
    Oct 2009
    Timisoara
    great help
  9. Re: Possible to disable immobilizer
    #19
    Oct 2009
    Mauritius
    Quote Originally Posted by Ashley231 View Post
    Thanks greeny....
    But how can i disable it....
    please help me.
  10. Re: Possible to disable immobilizer
    #20
    Magdeburg, Germany
    Thanks for the hint ecmbuster, not sure why we never corrected that page. Went over it again and made a couple of changes/additions which should make things clearer now.
    http://wiki.ross-tech.com/index.php/01176
    BTW: Personally I think disabling the immo is a waste of time and efforts, immo problems are easy enough to diagnose using proper tools and the data provided by the immo itself.
    Sebastian @ www.Ross-Tech.com
  1. Immobilizer issue?
    By ovidiucos in forum Bora - 1998 - 2005
    Last Post: 08-01-2008, 09:40 AM
  2. How To Disable Dim Dip
    By noppygolf in forum Golf MK3 - 1993 - 1999
    Last Post: 13-09-2007, 12:43 PM
  3. A4 Immobilizer problem
    By evster in forum Audi A4 - Archive Topics
    Last Post: 07-03-2007, 12:51 PM
  4. Immobilizer Help
    By MJB20V in forum Audi A4 - Archive Topics
    Last Post: 07-03-2007, 12:01 AM
  5. immobilizer & safety
    By trippin in forum 80 - 90
    Last Post: 03-09-2006, 05:31 AM
