Thread: Mmi
  1. Question Mmi
    Can anyone tell me exactly what functions can be done with the MMI, is it possible to set the car up for drive off locking, see you home lighting etc?
  2. Re: Mmi
    Quote Originally Posted by JohnsA4 View Post
    Yep, all those sorts of things. The full list will depend on what spec the car is! Generally the radio, bluetooth, climate control, parking sensors and other stuff is controlled through it. It's fairly intuitive.
  3. Re: Mmi
    Mar 2008
    As Andy says, it's a pretty long list. From memory it also covers bits like sensitivity of automatic lights and turn on/off daytime running. There's a section for the windows which I think changes the behaviour when the engine isn't running. You can turn on / off each item in the onboard computers (average speed, fuel econ, journey duration etc.). And so on...
    The only thing I haven't found is a switch to replace mini Sat Nav with the digial speedo. I can flick between audio and telephone as usual, but seems you lose speedo when being navigated.
  4. Re: Mmi
    I've the peasant's version without satnav, but have you tried hitting the button on the underside of the wiper stalk a few times? That gets me back to the mph display.
  5. Re: Mmi
    Scotland
    I think it depends how you spec the car up. My car has a few options that youcan change which I will check tomorrow for you, but I test drove one with almost no extras and you couldn't do much on that.
    If at first you don't succeed, re-define success
  6. Re: Mmi
    There's also a clock on the MMi which is really useful for reading what time it is.
    AUDI A4 2.0 TDi SE - Only enough money for-
    Hill hold assist
    17in 10 Spoke wheels
    Brilliant Red
    Rear Parking Sensors
  7. Re: Mmi
    Scotland
    And one on the rev counter
