Thread: Water Pump Replacement
  1. Water Pump Replacement
    Dec 2007
    Hi all,
    Would really appreciate someone pointing me in the direction of a "how to" guide (perhaps it already exists and I just can locate it) on replacing the water pump on my 1995 Audi 80 1.9tdi, SE Auto.
    I've started work on it and it seems like I need to remove the crank pulley, timing belt etc.
    It's turning into a much bigger job than I expected.
    Can some one please help?
    Thanking you all in advance.
  2. Re: Water Pump Replacement
    Dec 2007
    8 Post(s)
    Looks like you are right and then it seems like you have to
    remove pulley from intermed. shaft to access some water pump bolts
  3. Re: Water Pump Replacement
    Dec 2007
    Thanks for your response, it's all done now and she's back on the road.
  4. Re: Water Pump Replacement
    Dec 2007
    8 Post(s)
    Ooops. there is another way. remove complete water pump assy. by
    removing bracket that is over power steering pump. remove bolts from
    water pump to block remove one plastic cover bolt. lift off water pump assy.
    no need to disturb timing belt
    may help next person with replacement query
  1. water pump
    By stockportdubfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-11-2008, 10:03 AM
  2. A6 4.2 Water Pump/Timing Belt Replacement
    By V8A6inArnold in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-04-2008, 07:37 PM
  3. water pump t5
    By jess james in forum The Commercial Range
    Last Post: 11-01-2008, 06:22 PM
  4. Water pump replacement
    By felinor in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-06-2007, 04:17 PM
  5. water pump
    By garying3980 in forum Passat - Archive Topics
    Last Post: 27-02-2007, 06:34 PM
