Thread: engine wont even turn over!
  1. engine wont even turn over!
    hi guys, just bought a petrol 1.6 16v leon on a y plate and all was fine. on the drive home today the oil light came on, got home left it for about 2 hours and the immobiliser/locks started acting all funny, finally managed to get into the car and now the engine wont even turn over! have recharged the battery and also topped up the oil but to no avale!
    the engine doesnt even start to turn over, just the initial click and then nothing.
    Any help much appreciated!
  2. Re: engine wont even turn over!
    1840 Post(s)
    It sounds as though you may have seized it as these engines are prone to losing oil pressure and seizing the camshafts in the cam carrier. You need to see if it will turn over without the starter but be very careful as if it is seized, you could cause more damage. I would try turning it over at the front pulley using a ½ inch drive ratchet, long extension bar and 19-mm 12 point socket. Taking the plugs out will make it easier.
  1. ignition light on engine wont turn over
    By wendyjane in forum Touran - Sharan - Caravelle
    Last Post: 10-09-2009, 09:27 PM
  2. Touran 2.0tdi esp wont turn on
    By blackice100 in forum Touran - Sharan - Caravelle
    Last Post: 10-05-2009, 01:52 PM
  3. low beams wont turn on
    By ryon13 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-01-2008, 07:14 PM
  4. VW passat W8 fan wont turn off
    By LoveMyDUB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-12-2007, 06:58 PM
  5. wont turn over
    By kesn in forum Golf MK4 - 1999 - 2004
    Last Post: 10-10-2007, 09:04 PM
