Thread: Keyless cannot control boot lid
  1. Keyless cannot control boot lid
    We are fixing a 2007 Flying Spurt. The keyless works with starting engine, lock/unclock the doors but not the boot. We checked on electric wire from the trunk latch down to control modules. Evething is fine. We also replaced the trunk lid control module but still, no hope. Please help....
  2. Re: Keyless cannot control boot lid
    Hello!!! I had one of these and you could order a Valet key when you bought the car. It was programmed not to open the boot or the glove box and looked very similar to the normal key. Maybe check you've got the right key!!! Steve.
  3. Re: Keyless cannot control boot lid
    Jan 2006
    PRESTON, LANCS
    Quote Originally Posted by maily View Post
    Maybe tie a piece of string to the trunk latch -drill a few holes through the back seats-- insert a few rubber grommits Colour to suit the leather seats --of course)--thread the string through-and fix a curtain ring on the other end - . One pull- and 'hey presto' --It will never let you down.
    B and Q do balls of string- -so- no need to worry about 'spare parts' in the future .
  4. Cool Re: Keyless cannot control boot lid
    Apr 2010
    Pattingham, South Staffordshire
    Hi, I think you have put the car into Valet mode. You can change this by reprogamming, check users manual.
  5. Re: Keyless cannot control boot lid
    Aug 2010
    Buckinghamshire
    The bentley GT has aerials in the front and rear interior and behind the rear bumper, each for keyless entry. The front 2 aerials could be ok, which is why you can start the car via keyless and open and close, but the rear bumper one may have failed. Need to check fault codes and wiring from keyless entry ecu to aerial.
  1. Keyless Entry Interchangability
    By dadewiggles in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2008, 11:57 AM
  2. Keyless Entry
    By Slimbarry in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-09-2007, 09:16 PM
  3. boot warning sensor comes on the display when the boot is shut
    By merchantmr in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 10:04 PM
  4. Keyless entry
    By blackie in forum Passat - Archive Topics
    Last Post: 20-03-2006, 11:16 AM
