Thread: Help with fault code
  1. Help with fault code
    East Kilbride, Scotland
    I have Leon 1.4 2001 after VAG COM scan have found fault logged.
    Control Module Part Number: 1M0 035 186 C
    Component and/or Version: Radio 0001
    Software Coding: 00401
    Work Shop Code: WSC 06441
    1 Faults Found:
    00856 - Radio Antenna
    29-00 - Short to Ground
    I replaced the stem as the rubber was starting to perish, and cleared the fault code, but, the code logs again. Any directions to solving the problem would be appreciated.
  2. Re: Help with fault code
    1840 Post(s)
    It is the base at fault. Has the car got the original radio?
  3. Re: Help with fault code
    Yes the car has the original Aura head unit with disk changer.
  4. Re: Help with fault code
    1840 Post(s)
    Then I would think you have a faulty aerial base.
  5. Re: Help with fault code
    Thanks for that, i've read it's a bit of a pig to get at , but i'll try it and see if this cures problem.
  6. Thumbs up Re: Help with fault code
    New base fitted and reception now back to normal, fault cleared and not returning. Part number for base 1P0 035 501 ONLY £10.69 icl. vat from dealer, thanks again.
  1. fault code help
    By cornetbloke in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-01-2009, 08:36 PM
  2. VAG-COM fault code
    By carlthom in forum Golf MK3 - 1993 - 1999
    Last Post: 31-03-2008, 06:19 PM
  3. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
  4. Fault Code help
    By daveaustin in forum Golf MK5 - 2004 - 2009
    Last Post: 08-11-2007, 01:48 PM
  5. Fault code
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 08:41 PM
