Thread: Cambelt Change Advice
  1. Cambelt Change Advice
    Afternoon all,
    As it's my first post I'll start off by saying I have recently become the proud owner of an 'M' Reg GTI 8v (73k ADY engine). For the money I paid gotta say I'm chuffed with it. Needs a bit of tlc and has the usual irratic idle and cold cut-out problem but I've read about things I can do to address that.
    My mate and I are going to change the cambelt ourselves next week, he is experienced at such things having built MK2's from scratch but I was wondering if there was anything in particular we should be aware of before going for it?
    Much appreciated.
  2. Re: Cambelt Change Advice
    1840 Post(s)
    It is the same as doing an 8v Golf 2 but you will need VAG-COM to check the distributor position.
  3. Re: Cambelt Change Advice
    Thanks for the quick reply. I have bought a VAG COM cable but it is OBD2 I think but is my car OBD1? Where can I get a converter from any ideas?
    Cheers again.
  4. Re: Cambelt Change Advice
    1840 Post(s)
    An ADY should have the 16 pin plug behind the cover above the cig lighter, I can't remember ever seeing an ADY with the 2x2 plug. Are you sure it is ADY and not 2E?
  5. Re: Cambelt Change Advice
    Just had a go now the cable I bought fits fine into the port behind cig lighter. Only problem is my laptop doesnt have a serial port so just ordered a usb converter.
    Cheers again for your reply.
  6. Re: Cambelt Change Advice
    1840 Post(s)
    I think you will find that will not work, other people have tried that. You need a USB cable.
  1. Cambelt change...
    By domestos in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-07-2008, 10:44 PM
  2. 2.8 V6 Cambelt change
    By barryw in forum 80 - 90
    Last Post: 23-03-2008, 02:03 PM
  3. 2.0 FSI Cambelt change advice
    By phil1972 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2008, 10:26 PM
  4. Cambelt change
    By SMEG in forum Chat - Anything with wheels
    Last Post: 30-07-2007, 10:56 AM
  5. Cambelt Change
    By wg100 in forum Golf MK2 - 1984 - 1992
    Last Post: 30-03-2007, 09:16 PM
